Old 01-22-2008, 07:25 PM   #1
swpdwgn
swpdwgn's Avatar
swpdwgn is making a name for him/her selfswpdwgn is making a name for him/her selfswpdwgn is making a name for him/her self
Send a message via AIM to swpdwgn
Short Shift kit for rb
looking into getting a short shift kit for my rb20 but im skeptical to what i should get. will an s13 240sx one work or a 300zx? someone help me out, it would be much appreciated.
swpdwgn is offline   Reply With Quote
Old 01-22-2008, 07:28 PM   #2
MavericStephenc
MavericStephenc's Avatar
MavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfectionMavericStephenc is close to perfection
Send a message via AIM to MavericStephenc
get the one made for the car
www.google.com
edit: I believe the sr one fits but I'm not 100%
That kind of attitude is SHIT. People with that kind of complacent outlook on law and government are the bane of this country's existence. -Thesquidd
Boycott Berkeley and code pink
MavericStephenc is offline   Reply With Quote
Old 01-22-2008, 07:40 PM   #3
240love
240love's Avatar
240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection240love is close to perfection
KA/Sr/RB20 are the same
240love is offline   Reply With Quote
Old 01-22-2008, 07:53 PM   #4
swpdwgn
swpdwgn's Avatar
alright so i can go with a regular s13 one. thanks guys.
Old 01-22-2008, 08:34 PM   #5
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
nop you are wrong, i had an S13 SR20 short shifter, didn't work, you need other tranny parts to make it work, but im not going to search for you, so www.google.com knock your self out.
Review Thread
bardabe is offline   Reply With Quote
Old 01-22-2008, 09:24 PM   #6
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
! was under the impression that they all swapped in...i.e. S13/S14/Skyline. I know my buddy's Z32 has some linkage involved, but i thought the gearbox for the Skyline lined up with the car similarly to the S chassis?? I'm too tired and don't care enough to search either, but i am curious... post up when you find something.
The Chad is offline   Reply With Quote
Old 01-22-2008, 11:18 PM   #7
cronux
cronux's Avatar
cronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to allcronux is a name known to all
rb20 is same transmission as sr and ka. rb25 is different. and of course so is rb26.
EDIT: Bardabe, by some of the parts, did you mean you tried to install a c's style short shifter without having the original shifter pieces? because if you did, you need a wave washer and a bush socket.
cronux is offline   Reply With Quote
Old 01-22-2008, 11:58 PM   #8
bardabe
bardabe's Avatar
i had that, thing was the shifter wouldn't push it "all the way" into gear specially reverse, so i would drive and it would pop out of gear. i put the stock shifter in, and it worked fine. that shifter worked perfectly on my SR20. i know what parts they are i just dun remeber the name that's why im saying search on it i know its only like 1 or 2 things you change and u can get a KA shifter to work. B&M and others will work too once that mod is done
Review Thread
Old 01-23-2008, 04:44 AM   #9
onepuff
onepuff's Avatar
onepuff is on the path to ruinonepuff is on the path to ruinonepuff is on the path to ruin
I'm using a ka B&M shifter. I had to modify the base plate a little but it works perfectly now. Here's a little writeup i did on nico.
http://forums.nicoclub.com/zerothread/305486
onepuff is offline   Reply With Quote
Old 02-17-2008, 10:29 AM   #10
thatloserkidquinn
thatloserkidquinn is an unknown quantity at this point
The stock ka shifter is a direct match and it is shorter than the stock rb20 shifter
thatloserkidquinn is offline   Reply With Quote
Old 02-17-2008, 11:12 AM   #11
Jtuned_andy
Jtuned_andy's Avatar
Trader Rating: (28)
Jtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud ofJtuned_andy has much to be proud of
Feedback Score: 28 reviews
Anyone saying that the KA/SR are the same as an RB20 shifter are purely speculating and should stop. The KA/SR shifter fits RB20DE just fine but they are not a 100% bolt in for a DET. I read up on the subject awhile ago so I can't give you all the details but I know that if you want to use a KA/SR shifter it requires you to remove parts (internal shift arm?) from the KA/SR and install it into your RB20det tranny which is more work that it's worth unless you have the parts lying around and your tranny is removed from the car.
The only shifter available for sale currently would be a Nismo solid shifter for RB20DET, which is always a special order part from Japan.
I'm not going to link you to ebay auctions, but i'm sure you can find it.
http://home.comcast.net/~skunk.werkz/r32_sig.jpg
Jtuned_andy is offline   Reply With Quote
Old 02-17-2008, 11:18 AM   #12
burnsauto
burnsauto's Avatar
yeah heres the other option you mentioned.
http://forums.nicoclub.com/zerothread?id=112010
Old 02-17-2008, 11:42 AM   #13
Jtuned_andy
Trader Rating: (28)
+rep for you burns, that is the article I was thinking of
Old 02-17-2008, 01:33 PM   #14
burnsauto
burnsauto's Avatar
thanks man, i'll repay the kindness.
as far as the nismo shifter is concerned, does it actually shorten the throw, or does it just firm it up (like with the sr one..)
Old 02-17-2008, 02:11 PM   #15
Jtuned_andy
Trader Rating: (28)
I'm thinking it just tightens everything up, you know how Nismo does things, takes a stock part and just improves it a 'little' bit.
there is always cut and weld.
Old 02-17-2008, 02:31 PM   #16
hijack3d
hijack3d's Avatar
hijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond reputehijack3d has a reputation beyond repute
Absolutely right. KA/SR/RB are not the same. And if you look on ebay for a short shifter for your RB20 and see some (I think last I looked there were fidanza ones saying they worked for RB20), the fact is they work only for the RB20DE not T...
I would go with the B&M install for a KA and modify it to work. Doesn't look too difficult.
Don't worry, it's legit: Review (Thanks Mike)
hijack3d is offline   Reply With Quote
Old 02-17-2008, 07:10 PM   #17
onepuff
onepuff's Avatar
Here's the other route i took. It didn't require removing the trans either. Working perfectly too! Not pretty but functional. Wouldn't be hard to make it look pretty either.
