Old 02-18-2008, 02:14 PM   #3
d0pe240
d0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of lightd0pe240 is a glorious beacon of light
Originally Posted by DaPCWiz View Post
pull up the boot and check for oil where the piston seals.
How is the boot attached to the top? Maybe the rubber at the mount point of the boot just tore. It can happen after a while - I don't think its much to worry about.
do you mean pull up on the bottom of the boot? i did that and saw no oil. i guess ill check the top a little later. also that rubber boot, whats inside of it? cause i was feeling it at the top and it feels like something hard is inside. thanks.
d0pe240 is offline   Reply With Quote
