Old 02-23-2008, 12:39 AM   #1
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
ok so here is the update. all of my wiring is good, i pulled the entire harness again and rechecked its all good. I havent checked my CAS but i have a slightly larger concern after talking to a friend of mine that is a master tech for mercedes. he listened to it turning and said it almost sounds like im getting not compression, so tomorrow im going to compression test it. Ive done the ignition spark test as described above, i finally found a FSM for my car, its for an s14 but hopefully it will help me with my redtop. Um as far as anything else....ignitor is new, starter is new, ECU is new, i also have a mines ECU (IN CASE ) oh im definitely getting fuel, my timing is perfect, im just kind of at a stand still, i'm feeling like its gotta be something with the coils and/or the CAS hopefully its something simple cuz those are both expensive and im really not trying to give up on this thing. My fault though, i was making stupid power on stock internals and i ran the motor almost dry so yeah.
I appreciate all the help guys really, ill keep updating with any news.
Thanks again, Landin
landins13 is offline   Reply With Quote
Old 02-24-2008, 08:17 PM   #2
WISH ONE
... make sure you really check everything, i had 3 nissan master techs a stuck on why mine wasnt starting, they all looked right past the cas issue. good luck with the comp issue
