02-24-2008, 02:05 PM
#4
Originally Posted by juls213
What kind of 240sx is it? s13 or s14? If its s14 you are in luck because they have OBDII connectors and colsult port. The OBDII Port is located in the right side of the center console, right next to the radio. If its an s13 you will need a consult or you can get codes by using the ecu, there is a post about this. GOOD LUCK
its a obd1 s14!
read! hah
