Old 02-28-2008, 05:59 PM   #1
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
Z U L8R's 280z RB25DET *Mod list* / goodbye tribute
Sold the car to a close friend of mine. Here is the list of the mods it had, in case someone has similar goals in mind or u were just curious to wtf i had done to it.
I believe i was lifting the head cause hadn't yet retorqued the arp head studs, hence the dip around 5200rpm, but mainly Turbo Dave tuned me for 20psi on 93 octane (pump gas) and i put 100 octane in it, cranked it to 22psi then strapped it to the dyno for the 441 run to see what the air fuels were at 22psi, i wasn't tuned for 100octane nor 22 psi, here's a cleaner graph from an actual tune and not a dyno queen peak power graph after i swapped the rear end from a 3.9 to a 3.54
pink was 20psi pump gas with the 3.9 rear end old tune
red was 14psi "low boost" with the 3.54 rear end new tune
blue was 20psi pump gas with the 3.54 rear end new tune
you can see low boost holds the torque true all the way to redline
but 20psi at 6k rpm the turbo runs out of steam. .63 a/r is the smallest version of the gt30/76r , if i went to the .8X or the 1.X (bigger housing) it'd be a little laggier but it would support it all the way to redline. overall the 30r is a kick ass turbo if you want 400 or a little more.
*SUSPENSION*
energy suspension complete bushing kit
toyota 4x4 4 piston front calipers
*RIMS*
Riken 14x7's with bfg t/a 245/60/14's in the rear fronts are 215's
*INTERNALS*
Commetic Metal HG
ARP Head Studs
(that's it for these dyno's, first motor lasted 7 months, timing belt idler pulley locked up, shredded timing belt = bent 19 valves, dropped new motor in /w hg & studs, lasted a month, was at the drag strip and drove it home with uber blow by.the plastic vacuum T to the fpr/profec cracked so it under fueled & over-boosted aka leaned out the motor and fried the piston/rings. after that i did wiseco 8.5:1 pistons +acl bearings + new oe oil pump, lasted a couple months then threw a rod on the dyno cause the stock rod bolt snapped...worst thing was i paid for pistons,rods,bearings, & machine work, and got everything but the rods, but i put it back together instead of bitched about it so...that's on me)
*MODS*
GReddy intake manifold
GReddy timing belt
GReddy Profec
Walboro 255lph inline fuel pump
Q45 Throttle body
Z32 MAF (blow through)
Z32 n/a 5 speed transmission
OS Geiken Super Single 6 puck unsprung clutch & flywheel combo
Ebay bar & plate fmic 25" x 11.5" x 3" core (27.5" from tip to tip)
Apexi Power FC
DeutcheWerk 550cc side fed injectors
Precision GT30/76R .63 a/r hot side, .60 a/r compressor side
XS Power top mount exhaust manifold (had to angle the turbo flange away from the valve cover a little so the compressor housing could clear it)
Tial 38mm external wastegate (9-13lb spring)
AFCO aluminum racing radiator
N1 water pump
Gizmo phenolic intake manifold gasket
BCPR7ES @ .028 or BKR7E @ .028 gap
Buick Grand National Ignition coil pack
MSD 8.5mm Wires (if u buy the v8 kit they're longer than the v6 kit)
Blitz Bov
Magnaflow 3" muffler
*THE MEN BEHIND THE SCENES AND SPECIAL THANKS TO*
Wouldn't have done it without these guys
motor mounts by Joey Dacus @ Landrum Manufacturing
Intercooler pipe,exhaust, transmission mount & other various fabrications done by Turbo Dave @ TDF fabrication/mainstream
Tuned by Turbo Dave
Basically I'm not the best welder/fabricator so i had those fine fellas handle that for me. Everything else I did myself. My specialties are engine diagnostics and Wiring.
thanks also to all the guys at Mainstream Performance, Top Hat Performance, Lethal Injection and everyone else for their help and support.
*TMI*
I drove that 280z for about 2 years with the stock L28E around, then finally rb20'd it. the rb20 was ok for a couple months and i had this rb25 waiting and waiting and waiting for the 240z to be finished but it didn't, so i said f@#^ it and put it in the 280. Got a lot of kills with the Z.....
Basically I was getting the drivetrain situated in the 280z so once the body work was finished on my 71 240z, i would have a complete package. the 240z has all the suspension stuff already on it and bubble widebody fender flares molded into it. at this stage in it's 3 years in my possession. it's all in primer, rust free, with the flares, a molded in whale tail and beefier frame rails. the 240z should weigh in around 2300lb whereas the 280z was 2600lb. I plan on going 2j in the 240z because i want 600rwhp RELIABLY and 600 ain't gonna hurt a 2j.
here's some links to some vids i've made with the 280z
here's a 90mph 4th gear pull when it was 305rwhp@15psi on the ebay t3/t4
http://youtube.com/watch?v=fDMKovyAAWo&feature=related
here's giving a 436hp supercharged foxbody stang a car length head start, the Z had 391hp at the time
http://youtube.com/watch?v=xGcbAOLDo4o&feature=related
here's my very first time at a drag strip with it
i just like the way it sounds in this one, i was trying to get out of first gear as fast as possible so i wouldn't spin....lol@helluva trap speed for the weaksauce E.T.
http://youtube.com/watch?v=kjE70Cd6_Sg&feature=related
here's vs my friend chad with a 400hp srt4 (gtk500)
http://youtube.com/watch?v=NxjeREchpQU&feature=related
http://youtube.com/watch?v=X9JAj3DY6E8
the vid says gt30/71r but it was really a gt30/76r. i didn't notice that till later but too late. lol@ the music, it was an inside joke. that was on pep boys s-rated 245/60/14's with a 3.9 open diff...2.1 60' ftl >_< got traction?
then i got tired of the yellow and primer so i primed the whole thing
http://youtube.com/watch?v=ctxV2CbYNg0&feature=related
o3 zo6 (470rwhp) and for the record that evo ran 11.6's i think it was round 380rwhp
sorry for the novel, thanks for reading it all hehe
take care,
Dave
this is also my closure / good bye.....because i'll miss the 280
Now I begin my GT35R KA-T 72 Datsun 510. I would like a 9 second pass @@
Dave
WWW.myspace.com/Z_U_L8R
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 02-28-2008, 06:12 PM   #2
97s14kouki
97s14kouki is an unknown quantity at this point
man i loved that car!!! I used to watch those youtube videos all the time. hope your friend takes good care of it. Cant wait to see that 2j!!!
97s14kouki is offline   Reply With Quote
Old 02-28-2008, 06:21 PM   #3
sofo259
sofo259's Avatar
sofo259 is an unknown quantity at this point
shit i cant wait to see the 510 !!!!
sofo259 is offline   Reply With Quote
Old 02-28-2008, 06:28 PM   #4
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
lol i just had a shit load of fun watching all of those rolling start races. all those cars are awesome. your friend's M3 sounds crazy raspy but i freaking love it.
why would you get rid of that 280 that thing was a beast!!!
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 02-28-2008, 06:29 PM   #5
berz
berz's Avatar
berz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfectionberz is close to perfection
from one z owner to another. ur z was fast . gl with with ur future car
berz is offline   Reply With Quote
Old 02-28-2008, 06:29 PM   #6
alindeman1989
alindeman1989's Avatar
alindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to allalindeman1989 is a name known to all
Send a message via AIM to alindeman1989
Man thats sweet. I love the vid of the zo6
tofu man: Don't be cheap, and buy shitty high offset rims
alindeman1989 is offline   Reply With Quote
Old 02-28-2008, 08:46 PM   #7
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
Best of luck on your 510!
"Genius may have its limitations,
but stupidity is not similarly handicapped."
Big Bronze Rim is offline   Reply With Quote
Old 02-28-2008, 08:46 PM   #8
Z U L8R
Z U L8R's Avatar
thx fellas =]
the Z was fast but the 510 is fun as hell too. it was time to get out of debt and start a new project pretty much. my friend who's getting the Z knows who will have the faster datsun by next year jp jp. i have some other vids if yall want me to post em up. i just need to upload em. one is a 500rwhp 2007 z06 (i/e/h/tune), a gt35r s2000 (460rwhp) and a 500+hp c5 z06, then i have another of a 490hp s14 /w rb26, a 590hp c5 z06 /w spray and a 600hp c6 z06 /w spray. i'll try to get em up in a timely manner.
thx again for the compliments. we had good times in "betsy"
take care fellas,
Dave =]
Old 02-28-2008, 08:59 PM   #9
s14>integra
s14>integra will become famous soon enoughs14>integra will become famous soon enoughs14>integra will become famous soon enoughs14>integra will become famous soon enoughs14>integra will become famous soon enough
man that BMW was pretty raspy. Please post the other vids if its not a problem. Beautiful Z by the way.
s14>integra is offline   Reply With Quote
Old 02-28-2008, 09:05 PM   #10
89singlecamnoob
89singlecamnoob's Avatar
89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of89singlecamnoob has much to be proud of
Send a message via AIM to 89singlecamnoob Send a message via Yahoo to 89singlecamnoob
awesome post, sexy Z...good stuff!
"Alfa Romeo builds cars to be as good as a car can be...briefly." -Clarkson
89singlecamnoob is offline   Reply With Quote
Old 02-29-2008, 08:29 PM   #11
Z U L8R
Z U L8R's Avatar
here's a vid we made, the vengeance c5 z06 is the red one, lankhoss is the 2007 c6 z06 who is the camera car. on the c6 z06 it says 505hp but that's not to the wheels. stock they put around 430 to the wheels. Lankhoss has intake,headers,exhaust, and a tune....i wish those bpu's would give us 70rwhp lol, must be nice.
that s2k is pretty sick. he said it was stock internals with just headgasket and arp head studs. at 22psi he made 460rwhp which is what i believe he was running. he was pouring 118 in the gas tank lol.
my first run with lankhoss i was at 17psi. which he pulled me up top so i went to 18psi, still he caught back up 40-120 (z06 only has to shift from 2nd to 3rd lol), last run i was at 20psi, but it was breaking up so i had to let out, hence y u see my brake lights. good bunch of guys. we did that all in mexico on a giant treadmill of course =] here ya go
http://youtube.com/watch?v=DMdFOWkuXRY
Dave =]
Old 03-02-2008, 02:34 PM   #12
ct9a gsr
ct9a gsr is an unknown quantity at this point
seen this car in action. +1 great guy. fixed 2 of my 240's and my supra. i'm the reason lankhoss's zo6 isn't stock anymore hahaha...can't wait to see the 510, gl bro
Charles
ct9a gsr is offline   Reply With Quote
Old 03-02-2008, 08:23 PM   #13
Creizai
Creizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura aboutCreizai has a spectacular aura about
Really really like this thread +1 rep baby
Creizai is offline   Reply With Quote
Old 03-02-2008, 08:41 PM   #14
sr20boostn20
sr20boostn20's Avatar
sr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of lightsr20boostn20 is a glorious beacon of light
Send a message via AIM to sr20boostn20
Damn, sad to see it go.
That car definitely ran hard. Espically for the tires n diff it was on.
good luck with the 510, I was thinkin that was gonna be one of my next projects
sr20boostn20 is offline   Reply With Quote
Old 03-03-2008, 06:42 AM   #15
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
Noooooooo!!
Good luck with the 510, keep us updated, here and/or at least on the local forum.
Neejay is offline   Reply With Quote
Old 03-03-2008, 06:54 AM   #16
Antihero983
Antihero983's Avatar
as a fellow Z owner, that shit is fucking sexy.
why on earth did you sell it?!
Old 03-03-2008, 07:22 AM   #17
mayco_86
mayco_86's Avatar
mayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfection
Nice history of the Z. Sucks that you had to sell the car.
mayco_86 is offline   Reply With Quote
Old 03-03-2008, 08:58 AM   #18
Z U L8R
Z U L8R's Avatar
thx guys =]
I didn't HAVE to persay lol but now i took care of one big debt, got 6k so far in the 510, a clean auto s14 /w ac that i daily, a dohc s13 5 spd f/s, a ninja ex500 i'll probably end up giving to my girlfriend, and some cash in my pocket. someone tell me not to get this cbr 929 later this week lol
2300 miles, $5200 + arai helmet and joe rocket jacket...kinda hard to pass up considering i paid 6200 for my 2001 ZX7R (ninja 750) with 13k on the clock. i miss wheelies >_< and the weather is great!
http://myspacetv.com/index.cfm?fusea...deoid=20025260
just cruisin at about 70mph, camera car is kswann's gt28/71 sr20 s13.
http://myspacetv.com/index.cfm?fusea...deoid=20025680
first run i didn't hear the honk so i was basically filming zo-sick (590hp + spray c5 z06 red) and 198plus (blue c6 z06 600rwhp /w spray) do an all motor run.
second run was me vs zo-sick which he was spraying and got me. frickin gearing on vettes rules up top.
third run was me vs ivansnow's rb26 s14 /w twin hks 25/40's + cams (491rwhp) from a third gear roll cause he couldn't get traction from a second gear pull, which u see later hehe. he pulled me slowly, then i had to let off and get over a lane...
fourth run is from 198plus's cockpit (cool ass old man) vs zo-sick, both on spray lol , zo-sick = pwnt in that one
last run me and ivansnow went at it from a second gear roll.
rear coil overs & griffin radiator + fan/shroud on the way for 510
Dave =]
Old 01-31-2009, 10:39 PM   #19
Z U L8R
Z U L8R's Avatar
UPDATE ON THE 510
got the whole s13 rear subframe in the 510 with a 2" mini tub + z32 TT 3.6 r260 vlsd. the rear seats have been modified to fit back in place like nothing happened =]
that inline walboro 255 is going in the trash
ground control coil overs on the front with toyota 4 piston calipers
16 gallon fuel cell with sending unit + aeromotive eliminator fuel pump
z32 5 speed tranny /w custom front bellhousing to bolt up to the KA (projectrsdm, thanks for the z32 tranny, he's a great seller by the way LOL)
gsxr1000 individual throttle bodies (custom KA plenum in progress)
i have a polished b210 brake booster and currently using a 280zx brake master cylinder with a summit proportioning valve.
i had wilwood 4 pot rear calipers on the 510's rear but now i can upgrade the s13 rear to 5 lug and bigger breaks + s13 coil overs and all the fancy shmancy adjustable suspension crap.
the rust looks worse than it is, but here's the diff mount in progress =]
this is before the inner rear fender wells were moved for the mini tub
i'm excited, i really like the precision 62mm turbo with the billet aluminum wheel. spools up 100rpm later than the 61mm gt35r but will make 680AWHP on an evo therefore capable of supporting 600hp easily on a dohc KA24DE in a rear wheel drive car with as little lag as possible =]
I also have an aem ems for the ka at the shop.
here's a vid of the 510 on stock ka before she underwent surgery
L33T510 VID- Video
my widebody 71 240z has underwent more body work and is getting closer to seeing it's LSX motor + turbo. however i want the 510 done before the 240z. i'll post some pics of the Z when i get time to take some.
take care,
Dave @ Lethal Injection Motorsports
770-343-9969
Old 05-13-2009, 02:13 AM   #20
khmerpimpin
khmerpimpin is making a name for him/her selfkhmerpimpin is making a name for him/her self
Send a message via AIM to khmerpimpin
do you have any pics of the 71 240z
khmerpimpin is offline   Reply With Quote
Old 05-13-2009, 02:32 AM   #21
SochBAT
SochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfectionSochBAT is close to perfection
Send a message via AIM to SochBAT
that Z was sex as FUCK.
SochBAT is offline   Reply With Quote
Old 05-13-2009, 02:47 AM   #22
viperbite
viperbite is on a distinguished road
ahhh youre the man dave!
viperbite is offline   Reply With Quote
Old 05-14-2009, 08:44 PM   #23
Z U L8R
Z U L8R's Avatar
i don't have any pics of the 240z just yet but here's a vid i made of my little brother's FD rx7 and my old 280z with the new owner on breakin
YoshiFD3s, Devil Z, and Z U L8R extended version Video by Z U L8R - MySpace Video
770-343-9969
Old 05-22-2011, 08:34 PM   #24
Z U L8R
Z U L8R's Avatar
Muwhahaha I GOT MY Z BACK!!!!
MY FAVORITE PIC
I like the Carbon Fiber hood scoops ^_^ , now i just need to get her in a magazine
NEW MODS:
No more rust!!
New floor pans and frame rails
All new weather stripping
New rims/tires, 245 on the front 275 nitto's on the back. Rims are Rota's
Jdm mirrors
Bre rear wing
Corbeau racing seats
Over fenders
Brand new black with blue pearl paint job
Arizona Z car rear mustache bar
Motorsport auto full coil overs
CF hood scoops
CF steering wheel
Nismo shift knob
6k HID's
Defi Heads up display Tach/Speedo
Engine Mods:
JE 8.5:1 forged pistons
SPOOL rods
ACL race bearings
Commetic Metal HG
ARP head studs
Custom Clutch Specialty 500+hp 6 puck sprung pressure plate, unsprung disc
The rest is the same as before, motor has ~7,000 miles on it.
She is for sale, serious buyer only please private message me
God is good!!!
Dave
Old 05-22-2011, 08:40 PM   #25
Neejay
Neejay's Avatar
wtf man. haha
I was about to ask if you moved back to ATL, until I saw the palm trees in the last few pics. lol
I sold my RB25 s13 too...I think I'm out of the 240 game.
Old 05-23-2011, 08:31 PM   #26
Z U L8R
Z U L8R's Avatar
doh!! >_<
