Old 02-26-2008, 07:59 PM   #31
landins13
landins13's Avatar
landins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choiceslandins13 has made poor choices
so for those of you who have been helping me out, i know i said i wouldnt have an update for a while, but i figured out whats wrong, i snapped a camshaft in half. i have no idea how, but the engine had no compression because nothing in the head was turning, the intake cam snapped clean right where it attaches to the cam gear. im in the process of taking off the head to check and see if i have any bent valves i probly will, and at this point im thinking about buying a new head so if you see one let me know (dick tracy) i really appreciate it.
Landin
landins13 is offline   Reply With Quote
Old 02-26-2008, 09:14 PM   #32
slider2828
slider2828's Avatar
Did you follow torque procedures in the FSM? Only real way to snap the came, but if you cranked it with the valve open, you can be assured of a bent valve. Better safe to rebuild the head seriously or break it apart and chek all of the valves.
Turn and Burn!
Old 02-26-2008, 09:33 PM   #33
Big Bronze Rim
Big Bronze Rim's Avatar
Big Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the roughBig Bronze Rim is a jewel in the rough
Yup, I would say 99.999% of the time a broken cam is due to install error. Sucks to hear. You probably need to pull the head to check for bent valves.
Big Bronze Rim is offline   Reply With Quote
Old 02-26-2008, 09:38 PM   #34
GuardianLlama
GuardianLlama's Avatar
GuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfectionGuardianLlama is close to perfection
Sr's are interference motors?
I didn't think that they were.
but I'm still a
GuardianLlama is offline   Reply With Quote
Old 02-26-2008, 09:51 PM   #35
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
Originally Posted by johngriff View Post
Sounds like it has no compression? You would know.
Fuel + Spark + Compression + Air + Timing = Run. Its got to be one of those 5.
.fixed it. . . . . .
"I am Norwegian, and are not familiar with your urban words :P"
jskateborders is offline   Reply With Quote
Old 02-26-2008, 11:30 PM   #36
landins13
landins13's Avatar
heads off, now bent valves, how the hell this happend i have no idea im still trying to work things out.
Old 02-27-2008, 01:36 AM   #37
slider2828
slider2828's Avatar
You probably didn't torque the cames center outwards like FSM. THe cam snapped, and the valves stayed down or open. You cranked the car and the piston's slapped into the valves hence bent valves. Since you know you have bent valves, you might as well rip the entire engine out as you probably will have nicked the pistons a little or just really clean on the bottom end...
Turn and Burn!
Old 02-27-2008, 07:47 AM   #38
Big Bronze Rim
but I'm still a
It is. And the OP unfortunately has bent valves to prove it. Time to build the head and upgrade cams! You MUST follow the proper torque sequence or broken cams WILL be the result.
Old 02-28-2008, 01:40 PM   #39
landins13
landins13's Avatar
i did follow the proper torgue sequence and had them torqued down properly, i was bolting down the trans when my buddy reassembled the head, and he flopped the cams, he had the intake cam on the exhaust side and vise versa. the head is toast, im buying a whole new one.
Old 02-28-2008, 10:20 PM   #40
Gjohnson7
Gjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura aboutGjohnson7 has a spectacular aura about
So, I assume you and your buddy are going half on a new head???
Well, lesson learned. Next time you make sure you handle the most important part and tripple check your work.
LSX Kouki Project, swap completed in Dec 09
Gjohnson7 is offline   Reply With Quote
