Old 01-27-2008, 02:43 PM   #31
nousablenames133
nousablenames133's Avatar
nousablenames133 is making a name for him/her selfnousablenames133 is making a name for him/her self
I'm sort of wondering what made you rule out the idle air control valve so quickly?
nousablenames133 is offline   Reply With Quote
Old 01-27-2008, 02:47 PM   #32
S13Boosts
S13Boosts's Avatar
S13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfectionS13Boosts is close to perfection
cause when i used to drive it when it was cold,i had no problems with the IACV.
S13Boosts is offline   Reply With Quote
Old 01-27-2008, 02:57 PM   #33
240trooper
240trooper's Avatar
240trooper is a well-known jackass
Send a message via AIM to 240trooper Send a message via Yahoo to 240trooper
yea, you souldnt clean the maf with anything you could mess it up more, anyways, change ur pcv its like 5 buxs, are you running a stock intake box set up? ohh yea, didnt u rebuild this engine recently?
2.7L
240trooper is offline   Reply With Quote
Old 01-27-2008, 03:31 PM   #34
nousablenames133
I didn't have any problems when it was cold either. Someone correct me if I'm wrong, but I'm going to guess the IACV regulation is only active when the engine is at normal operating conditions.
Old 01-30-2008, 02:52 PM   #35
S13Boosts
S13Boosts's Avatar
just cleaned the IACV same old problem! AH!
Old 01-30-2008, 05:39 PM   #36
S13Boosts
S13Boosts's Avatar
yessir ur correct!
Old 01-31-2008, 12:32 AM   #37
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
i think you should open her up and reset timing.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 01-31-2008, 11:31 AM   #38
MadMaverick
MadMaverick's Avatar
MadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really niceMadMaverick is just really nice
High idle, misfiring...did you ever bother looking for a vacuum leak? When it starts chugging, spray some carb clean around the area of the intake manifold/hoses, ect. If the idle calms down or changes, you have a vacuum leak. Use more direct sprays to narrow down the area of the leak and fix it.
MadMaverick is offline   Reply With Quote
Old 01-31-2008, 05:17 PM   #39
S13Boosts
S13Boosts's Avatar
damn thats alot of work...i just wanna get rid of this car already LOL! gotta fix it before i sell it tho,yeah i havnt checked for any leaks yet ima do that after im done bein sick!
Old 02-12-2008, 04:31 PM   #40
S13Boosts
S13Boosts's Avatar
damn, aint no luck with my motor.. anymore input i think i have to reset the timing...
Old 02-17-2008, 01:04 AM   #41
seto_s14
seto_s14's Avatar
seto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud of
Send a message via AIM to seto_s14
Originally Posted by projectRDM View Post
Bad CTS. Swap it.
would a bad CTS cause crappy idle as well?
i have the same problem. when my dohc starts bogging/hesitating the temp gauage shows that the motor's getting cooler.
San Gabriel Car Detailing
https://www.ocdshine.com
seto_s14 is offline   Reply With Quote
Old 03-05-2008, 04:45 PM   #42
eclipse_dsm
eclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond reputeeclipse_dsm has a reputation beyond repute
I had a bogging issue as well on my DE-T b4 and practically did the same thing as you but mine turned out to be a loose connection on the ECU. Had to zip tie the connector on both edges to make a good contact not just rely on 1 bolt. Something I learned >** Never tigthen the ECU connector too much it will bend **. Fo you I would check ground or any possible loose connections specially to the sensors.
eclipse_dsm is offline   Reply With Quote
Old 03-06-2008, 12:16 AM   #43
S13Boosts
S13Boosts's Avatar
yeah i`ve been thinging about that but there`s to many to start out with,its nothing now i have spare time to check it out!
