Old 02-01-2003, 02:40 PM   #1
IchigoMae
IchigoMae is an unknown quantity at this point
Send a message via AIM to IchigoMae
KA KA-T External Fuel Pump
I am about to install an external fuel pump. any pointers?
IchigoMae is offline   Reply With Quote
Old 02-01-2003, 10:28 PM   #2
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Definitely:
1. Release fuel pressure following the same procedure for injector or fuel filter removal.
2. Make sure you point that thing in the right direction.
I think:
Mount it after the fuel filter and near the fuel rail. IIRC, Greaser's old setup had it mounted on the passenger side strut tower.... from what I'm thinking (I don't know for sure), it should be able to work more efficiently with less hose to fill/ work against.
AceInHole is offline   Reply With Quote
