Old 03-15-2008, 02:30 PM   #1
N97746
N97746 is an unknown quantity at this point
Center bearing support bolt problem
Pulling the driveshaft for a 5 speed swap. One bolt on the bearing support bracket came out fine. The other loosened a few threads and now will spin forever. Looks like there are threaded inserts in the chassis. I'm thinking one of the inserts has broken free, but I can't see up there to see if it's turning. Sooo, bolt won't loosen and bracket won't fall free.
Anybody have this problem or have any ideas ?? Thanks
N97746 is offline   Reply With Quote
Old 03-15-2008, 02:33 PM   #2
shade
shade's Avatar
shade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond reputeshade has a reputation beyond repute
How far is the nut off of the bolt? You maybe be able to weld the bolt on the chassis still.
Edit: Forget what I said...
shade is offline   Reply With Quote
Old 03-15-2008, 03:42 PM   #3
N97746
If I can get the bolt/threaded insert to come out I would weld the threaded part back in. I'm just guessing that the insert broke free. I can't see up there to be sure. Pulled the seat out and cut the carpet to see if I could get to it from inside but no luck
Thanks, any other ideas? Have been thinking a can of gas and a match, but I know as soon as I throw the match, the bearing bracket will fall free on it's own.
Old 03-15-2008, 03:47 PM   #4
ericcastro
ericcastro's Avatar
if you can, wedge something between the body of the car, and the bolt head. then, as you turn, pry them apart. That may put enough pressure on the bolt to help find the threads again, or hold the insert still so the bolt can unscrew.
or get a one piece shaft for a few hundred
Old 03-15-2008, 07:16 PM   #5
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
Easy fix, get a one piece driveshaft made and never look back. Its lighter and you do not lose as much torque transfer or hp, due to how sloppy center support bushings are in the first place.
New Video
Buy my mounts!
