Old 03-20-2008, 06:30 PM   #11
Def
Originally Posted by ctnewman View Post
I disagree. Loading the drive gear off-center AND partially is a huge stress riser.
Inline 6 cylinders are very well balanced.
Balance has nothing to do with torsional vibrations. You are speaking of external vibrations anyway, which is not what I'm talking about.
The crank twists back and forth like a tuning fork vibrates, which is why the factory puts on a harmonic damper(i.e. the crank pulley).
Let me put it this way, you externally spin the engine to 8000 RPM and the oil pump gears won't feel much load at all. You start running the engine and the torsional vibrations in the crank will rise and fall according to the 2nd order mechanical response of the engine's rotating assembly. This vibration GREATLY loads things.
Yes, the structural design of the gear probably isn't ideal, but the reason why it is failing is because it can't put up with the stresses it experiences due to torsional vibrations. It's probably easier to calm TVs on the crank than to make things strong enough to deal with an unfavorable vibrations environment.
