Old 01-25-2008, 04:29 PM   #1
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
Thumbs up HOW TO: J30 e-brake cable for S13
Hopefully this open up more oppurtunity to use J30 rear hub/spindle assemblys on your S13 and S14 (I'll do a similar write up on the S14 soon).
S13
What is needed:
0) J30 rear hub/spindle assembly and LCA
1) S13 ebrake cables left and right side
2) J30 e-brake cables left and right side
3) Dremel with Metal cut off wheel
4) Ruler than can measure in millimeters (recommended)
5) Sharp razor blade or box knife
6) Cable swagging tool (this is the crimper)
7) Oval shaped copper sleeves (this is what gets crimped)
8) 3/8" rachet with 10mm, 12mm, 14mm sockets
9) Needle nose pliers
(10) 2x4 wood atleast 5 ft long
Im not going to go into super detail im just assuming you know the gist of what to do allready and if you dont sorry.
PAY ATTENTION TO MY MEASUREMENTS IF YOU WANT YOUR SHIT FITTING GAME TIGHT!!! LOL
First you can start by taking your stock ebrake cables and cutting them like so (pic below x2):
Second you can cut the end of your cable to look like this (you can cut either from your stock cable or the J30 cable) you have some room for error. Pay attention to the measurements of the entire lenght of cable and the amount of shielding left in place, this was done on purpose.
Special note here, if you haven't cut off the end piece becasue you used the one from the stock cables now is time to do so on the J30 cables so you can complete remove the cable to avoid cutting it.
Third take your J30 ebrake cable and cut this off exactly like pictures:
Notice the end piece is cut off here, this allows for removal of inner cable so you dont cut it in half:
I'll update more in a little bit till complete.
Heres a picture of the end result, this is what it should look like when done, I need to go outside and take a picture of the overall cable lenght before end piece attached but its raining so maybe tomorrow:
Old 01-25-2008, 09:49 PM   #2
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
looks good its one of the better jobs i have seen
deesz is offline   Reply With Quote
Old 02-02-2008, 11:21 PM   #3
pacefarm
pacefarm's Avatar
pacefarm is an unknown quantity at this point
Send a message via AIM to pacefarm
props on the write-up. glad someone went through the trouble explaining this with pictures to go along.
how different do you think the job for an s14 would be?
pacefarm is offline   Reply With Quote
Old 02-02-2008, 11:29 PM   #4
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Same but ofcourse different lenghts, I'll be working on a S14 soon and i'll do my best to document that one as well, I still need to finish up teh S13 one on this thread first. Thank you.
Old 03-21-2008, 06:52 PM   #5
cbates14
cbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond reputecbates14 has a reputation beyond repute
Send a message via AIM to cbates14
great write-up!!! really appreciate you sharing this with everyone!
do you have any info on the s14 cable setup yet?
cbates14 is offline   Reply With Quote
Old 01-14-2009, 01:31 PM   #6
Shift n Drift
Shift n Drift has a little shameless behavior in the past
yo, i have the whole rear assembly and shit, but i mighta cut the j30 cable too short when i was at the junkyard, and that one pic after you said
"Third take your J30 ebrake cable and cut this off exactly like pictures:"
is that metal piece from an s13 or j30, if its the j30 i dont got it.
could you send me a pm, cause i prolly wont find this. thanks
Shift n Drift is offline   Reply With Quote
Old 01-14-2009, 01:37 PM   #7
Shift n Drift
my bad for bringing back a really old thread, i google j30 ebrake cable and found this
Old 01-14-2009, 02:05 PM   #8
projectRDM
projectRDM's Avatar
Since it was dredged up, the cables work fine on an S14 if you make a set of brackets, similar to the Z32->S13 brackets. I did two cars a few months ago using the J30 rears, no cutting of the cables was needed.
FORMERLY R240NA
Old 01-17-2009, 01:33 AM   #9
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Just like it says brotha, J30. That is cut from the J30 cable, this mod to teh cables was specifically for the S13.
Old 10-24-2017, 06:22 PM   #10
danman04x
danman04x is an unknown quantity at this point
Bringing this thread back from the grave. I just sis this exactly as per directions and the cable seems to be too long. Installed them and still dont have a parking brake. Did you ever get those full measurments of the cable??? Sorry to bring back something so old
danman04x is offline   Reply With Quote
Old 10-24-2017, 06:26 PM   #11
anti tyler
GM2 (SW/AW)
anti tyler's Avatar
Trader Rating: (37)
anti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfectionanti tyler is close to perfection
Feedback Score: 37 reviews
Send a message via AIM to anti tyler Send a message via Yahoo to anti tyler
Did you adjust the parking brake itself & did you re-mount the cables back to the subframe, or just leave them dangling?
WillEastS14:
mannn u whylin son.
but that shyt has SWAG
KA-T for life!
Current for sale advertisement
anti tyler is offline   Reply With Quote
Old 10-24-2017, 06:39 PM   #12
danman04x
what do you mean adjust the parking break itself? I mounted the cables back to the subframe. I pull my ebrake and its not pulling on the lever mechanism in the parking break assembly like the cable is too long or has too much slack
Old 10-24-2017, 06:41 PM   #13
danman04x
Just so im right on the directions you only end up cutting the j30 ebrake cable 43mm correct?
Old 10-24-2017, 07:16 PM   #14
3NDLESS
3NDLESS's Avatar
3NDLESS is an unknown quantity at this point
He means
That little adjustment "knob" thing below the spring on the bottom of the assembly; have you touched that?
3NDLESS is offline   Reply With Quote
Old 10-24-2017, 07:34 PM   #15
danman04x
Yea i messed with it a bit. i could try tightening it more but dont really see how thats going to make big difference. I even tried adjusting the cable at the ebrake handle. I pull the handle and there is no resistance
