Simple answer: No, the switch panel is not required.
Long answer: See any of the above posts. It seems like he does know what he is talking about. I would suggest you read carefully before you post an assumption.
Do need the Factory Service Manual? Click here. |
![]() Join Date: Dec 2005
by using a painless kit and NOT using the factory switches in the car you eliminate wiring, most of which is not needed. this is the reason that comment was made to him. Painless is usually for race car purposes and painless doesnt just control headlights turn signals, it is usually used to turn off fuel pump...ecu...starter...ignition...things along those lines...
#3 | |
![]() Join Date: Feb 2005
I'm not saying I know a ton, but posts like that just aren't helping anything regarding the topic. PS. Listen to g6civcx. He knows what he's talking about. Haha. |
#4 | |
![]() Join Date: Apr 2004
I don't know about all that, but thanks for the vote of confidence. Really, I can help you run just about any custom wiring you want. The problem is complexity. Even if I draw diagrams for you, you still have to think about wire gauge, routing, connections, grounds, insulations, etc. when you actually make the circuit. Why are you doing this? If you just want to simplify, just eliminate all the components you don't want. Any wires going to these components, provided they don't piggyback off or is used by something else, can be eliminated. |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
I've seen 3 0r 4 different people ask this with no answer, WHY are you interested in this? If it is to save weight and reduce complication on a car that is for street AND track you would be better off forgetting the painless stuff and re-doing your stock wiring. If you had a fire or something happened that destroyed your wiring then just get some used factory harnesses and re-do them. If you are building a full out racecar then use the painless stuff as it will remove a BIT more weight and the wiring will be a bit less complicated.
This company is cheaper and does the same thing:
![]() http://www.ezwiring.com/wiring_harness.html But, yeah why do you want to rewire the car? Is your wire harness missing or damaged? |
