Old 04-02-2008, 01:37 PM   #1
Xandy Boosts
Xandy Boosts's Avatar
Xandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfectionXandy Boosts is close to perfection
Send a message via AIM to Xandy Boosts
Half of small coolant hardline broke off
with a small hose clamp, do you think it will hold the pressure? or do you think it'll blow off
Here's a pic
this is the one that comes from the throttle body
Wil it hold?
it's a RUCKUS life
Xandy Boosts is offline   Reply With Quote
Old 04-02-2008, 01:40 PM   #2
corriganjoshua
corriganjoshua's Avatar
corriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfectioncorriganjoshua is close to perfection
Send a message via MSN to corriganjoshua
I had a buddy that did that and it blew off...if that helps at all haha
Team Inertia
Cheap,Fast,Reliable you can only have 2.
corriganjoshua is offline   Reply With Quote
Old 04-02-2008, 01:43 PM   #3
Xandy Boosts
shit lol
I got an idea, what if I bypass the damn throttle body lines altogether
here I circled it
the one with the X used to go from there to the upper radiator hose waterneck
what if I just skip that and go from the circle to the upper radiator neck
that should work right
it's a RUCKUS life
Old 04-02-2008, 05:39 PM   #4
bizzyj83
bizzyj83 can only hope to improve
Is this for a SR or KA??
KA throttle bodies aren't too expensive.. so I would suggest you replace it, unless you want to bypass it?
It's just so the tb doesn't stick in cold weather.. and based on your avatar, you're in a warm area so it shouldn't matter too greatly.
Z owners bypass their TB coolant lines...
bizzyj83 is offline   Reply With Quote
Old 04-02-2008, 05:55 PM   #5
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
i belive those are removeable
see this thread
http://www.zilvia.net/f/showthread.php?t=176575
importdude is offline   Reply With Quote
Old 04-02-2008, 07:25 PM   #6
Xandy Boosts
Yup, I'm bypassing those mofos! Tomorrow, I clean my intake mani. Friday, parts come in, everything put back together. And I finally get to drive my car again after 2 weeks! (Finals and a small trip put off time to work on car)
it's a RUCKUS life
