Old 02-10-2003, 08:18 PM   #1
four
four's Avatar
four is an unknown quantity at this point
Send a message via AIM to four
s14 before i buy tires, just wanna confirm with everyone
planning on getting 225/50/16
rims are 16x7 4x114.3 +40 offset
my suspension is KYB AGX w/ sus tech springs on a s14.
that setup will be okay with those tires right?
four is offline   Reply With Quote
Old 02-10-2003, 08:58 PM   #2
adey
adey's Avatar
adey is an unknown quantity at this point
you may rub your springs/agxs with the tire since it will be bulged a little bit, but you'll more likely than not be fine.
Instagram: @SX180HKG
adey is offline   Reply With Quote
Old 02-10-2003, 09:28 PM   #3
four
four's Avatar
so shuld i get 215s insteaad?
Old 02-10-2003, 09:55 PM   #4
HaLo
from Canada, eh!
HaLo's Avatar
With 16x7.5 +40 offset wheels and 225/50ZR16 tires I barely clear the springs... and when I say barely, I can't pass a finger.
-> HaLo
Race Car: '98 E36 BMW M3
SOLD: 01 GPW Honda S2000
Old 02-10-2003, 11:13 PM   #5
piratepete420
piratepete420 is an unknown quantity at this point
On an s13, there's about 8 mm (guesstimate) of clearance in the front with 225/45r17 on 17x7's. As apposed to 215's the sidewall will be more stretched on the 225's, meaning it'll be stiffer, and allow for better turn in response, right?
piratepete420 is offline   Reply With Quote
Old 02-10-2003, 11:57 PM   #6
AKADriver
AKADriver's Avatar
baaaaaaaah... A 225/50 won't be 'bulged' on a 16x7. It's fine.
As for tire clearance with a 225/50 on a +40 wheel, I'm curious myself. But, it looks like it'll fit (just guesstimating based on my current huge baloony 205/60-15 setup with the stock +42? steelies). I think i've got 10mm on the inside to spare. I hope.
Old 02-11-2003, 12:35 AM   #7
240fluke
240fluke is an unknown quantity at this point
http://toy4two.home.mindspring.com/offset.html
Tim '95 SE
240fluke is offline   Reply With Quote
Old 02-11-2003, 02:52 AM   #8
adey
adey's Avatar
Judging by HaLos clearance (or lack thereof) I would venture to say that your chances of clearing are slim. Go 215/50/16.
Also, a 225 tire will bulge a little (depending on the tire) on a 7" wide wheel. "proper" width for a 225 tire is 7.5". It will fit, however, without problem.
Old 02-11-2003, 08:56 AM   #9
AKADriver
AKADriver's Avatar
215/50 is kinda short, I'd just suck up and go 205/55 if I was going to do that.
Look up the specs on any 225/50-16 tire. They use 7" as the measured rim width.
In fact, speaking of tire specs...
Let's look at a tire that comes in a buttload of sizes... say, the Yoko AVS ES100.
In 225/50-16 on a 16x7" rim its section width is listed as 8.9".
In 205/60-15 on a 15x6" rim its section width is listed as 8.2".
So the 225/50-16 will be 0.7" wider, requiring an extra 0.35" (9mm) on the inside than my current tire setup.
I think it should fit. It'll be tight.
All the more reason to get low-offset wheels
Old 02-11-2003, 09:07 AM   #10
four
four's Avatar
now i dont know what to get
Old 02-11-2003, 09:22 AM   #11
adey
adey's Avatar
heh... you should go get some of that lovin' that your avatar is offering you!
I think your main problem is the WHEELS. If you can sell them (for more than you paid) to some accord owner and buy some nicer LOWER OFFSET wheels (and then hookup with the hot sales chick that sold you the new wheels), that would be ideal.
Old 02-11-2003, 09:32 AM   #12
HaLo
from Canada, eh!
HaLo's Avatar
Hum... Doesn't the S14 have more clearance then the S13? I just stated my case without noticing that he has a S14...
-> HaLo
Old 02-11-2003, 09:33 AM   #13
four
four's Avatar
Only in a perfect world.
Old 02-11-2003, 09:37 AM   #14
adey
adey's Avatar
Good point, HaLo... I didn't notice that either. I don't know if backspacing is the same as S13s, but I know that you can fit at least a 1/2" wider wheel/tire on an S14 than you can on S13... my guess is that backspacing is similar, though... but with even more room back there, a +40 wheel will just look worse (more sunken in... although some people like that look...)
If you want to be safe: go with 215.
If you're willing to take a little bit of a risk: go 225.
If you're buying a **** tire, go 225. If you're buying a nice sticky tire, go 215 (you reallllly wouldn't want to rub on a nice expensive sticky tire, whereas cheapos are disposable... to an extent.)
Old 02-11-2003, 10:03 AM   #15
four
four's Avatar
yep, i guess im going 215s
thanks guys
