Old 02-11-2003, 01:09 PM   #1
90240ka
90240ka is an unknown quantity at this point
KA hesitating motor
I have a 90 240 coupe, and I have tried countless times to fix this problem.
Problem: When I start my car, my revs steadily drop from .837(normal idle) to .350 then jump back up to 1.40 and it does the same thing until the car has totally warmed up, then is stays in between 1.000 and .750
Solution: I have bought new fuel injectors, plugs & wires, Fuel Filter, I am tempted to buy a new fuel pump, but thought I would come here and get some suggestions, before I spend more money, and not getting the problem fixed.
I also have another problem, my heater vents are not working, my defrost works, that is my only form of heat right now, I dont know if this is mechanical or and electrical problem. if you guys could help me out it would be greatly appreciated.
dreamin of droppin in an sr20det
90240ka is offline   Reply With Quote
Old 02-11-2003, 03:04 PM   #2
Tyler Durdan
Tyler Durdan's Avatar
Tyler Durdan is an unknown quantity at this point
It could be an o2 sensor that causing the fluctuation at idle. As for the heater vents, is it that no heat comes out, or no air at all. If it's no air at all, check the vent motor (don't know the exact name of it)...it's electrical. Autozone, or dealer depending if you want to spend the extra bucks for the oem part. Easy fix...takes about ten minutes. It's located at the passenger side near the firewall I believe...that's where they are on most cars, but check under your hood and see if your getting voltage from it. It could also be a blown fuse or short in the wires somewhere, but my money's on the the motor.
"Pure adrenaline attached to a license plate.  Isn't it time to experience one yourself?"
                        -Dan Gurney
Turbo for Sale
Tyler Durdan is offline   Reply With Quote
Old 02-11-2003, 04:44 PM   #3
90240ka
wheres the 02 sensor
I am pretty damn new to this car, and I am wondering where the o2 sensor is located.
Old 02-11-2003, 06:22 PM   #4
mrmephistopheles
mrmephistopheles's Avatar
Look near the bottom of the exhaust manifold.
Old 02-11-2003, 06:50 PM   #5
90240ka
found it......I think
I believe I fould it, how do I know that it is bad or not.
