Old 04-24-2008, 08:15 AM   #1
the head
the head's Avatar
SR Fuel Pressure Problems
Running a Sard regulator set to 43 with no vac all -6 line new fuel filter and rather new Walbro pump, 550cc injectors top feed.
As soon as the boost comes up out of vac the pressure drops to 20 but according to the wideband hooked into my haltech I am still running full rich (5V)
any help is appriciated
Old 04-24-2008, 08:33 AM   #2
posdrift240
posdrift240's Avatar
posdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymoreposdrift240 is not welcome here anymore
What fuel pump are you running?
posdrift240 is offline   Reply With Quote
Old 04-24-2008, 11:56 AM   #3
the head
the head's Avatar
walbro walboro 255 high pressure
Old 04-24-2008, 12:06 PM   #4
los_inc
los_inc's Avatar
los_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond reputelos_inc has a reputation beyond repute
Send a message via AIM to los_inc
make sure all the rings on the fuel rail are in decent shape also make sure your rail is properly secured your not loosing fuel pressure from them
-los
goodluck
los_inc is offline   Reply With Quote
Old 04-24-2008, 03:14 PM   #5
the head
the head's Avatar
yup no leaks under pressure
Old 04-24-2008, 04:14 PM   #6
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
ok, well typically on the stock fpr when the manifold is pressurized the fpr will increase fuel pressure about 1psi per pound of boost. as you can see with the stock fpr there is a vacuum line from the throttle body to the fpr. If there is a vacuum port you should have it connected. remember that static pressure and volume are two different elements.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 04-24-2008, 04:22 PM   #7
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
make sure the wiring on the fuel pump is not backwards
bigOdom1 is offline   Reply With Quote
Old 04-24-2008, 04:25 PM   #8
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
are you sure you have the correct fuel line going into your rail?
there is common confusion with the source line an the return line.
it sounds like your fpr is "stuck" and not reacting to boost.
give us the background on what the setup was before the new fpr and an fittings, fule pump, etc
did everything work ok before your upgrades?
clark is offline   Reply With Quote
