Old 04-25-2008, 08:45 AM   #1
drkidd22
drkidd22 is an unknown quantity at this point
SR SR Turbo Intake Nipples
Hey Guys,
I put an intake in the other day and I'm left with two nipples on it on the open. So I think is for a recirculating BOV or something but here is a pic.
Thanks
drkidd22 is offline   Reply With Quote
Old 04-25-2008, 09:10 AM   #2
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
The one on the right could be for your BOV recirc, or catch can (whichever isn't already attached to the bung you didn't circle). The circled bung on the left...don't know what that one's for. Plug it with a vacuum cap if you don't need it.
Is that a K&N brand intake pipe, or something else?
Also, what's that filter part #? Did it come with the MAF intake pipe adapter?
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 04-25-2008, 09:23 AM   #3
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
that's a vac linie for your WG actuator or boost controller. that's pretty cool it has a nipple on it.
EDIT: oh crap, it's pre-turbo, no boost source, i'm retarded
clark is offline   Reply With Quote
Old 04-25-2008, 09:24 AM   #4
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
i would rather plug it up then use it as a vaccum source
Old 04-25-2008, 10:07 AM   #5
drkidd22
Yeah. The kit came just like that. The only problem with it is that the adapter to the K&N filter is for the SR Stock MAF. I'm using the SOHC maf from the KA and had to drill some holes to adap it. I don't have a BOV so can I just seal the other nipple?
Old 04-25-2008, 10:14 AM   #6
drkidd22
Just the filter is K&N
Old 04-25-2008, 10:15 AM   #7
drkidd22
Can you elaborate a little on that? Source for like what?
Thanks.
Old 04-25-2008, 11:20 AM   #8
180sxLove
180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about180sxLove has a spectacular aura about
just plug the small bung.. you don't need it. the other one is the for the intake hose running from the stock catch can setup.. You can either use it the way it was intended to be ran from the factory or use it as a opportunity to recirculate your BOV to it and figure out another setup for your catch can..
hope this helps
180sxLove is offline   Reply With Quote
