Old 02-19-2003, 06:22 PM   #1
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
Originally posted by phil93_93
thanks for the info....what whould be the best limited slip?
that's highly debateable.... probably between kaaz, cusco, nismo, etc.
one more question....when i do a burn out it leaves 2 marks but useally one is longer then the other. i forget witch one tho. why is that if i have an open diff.???
Just because you have an open diff doesn't mean you can't burn out with 2 tires. If you do burn out with both tires it just means power is being evenly distributed across the diff.
AceInHole is offline   Reply With Quote
