s13 sr into s14 wiring problem/question
My fuel pump is not priming, and im not getting spark. i followed the same s13 sr into s14 wiring write up that everyone uses perfectly and my car is not starting. it cranks but no fuel or spark
i found this plug hiding up under the carpet under the kick panel. it looks like it goes directly to the fuel pump, im thinking obviously this is a big problem if its not plugged in. i tried looking for like an hour trying to figure out where this plugs into and i cannot find it. Can someone tell me? Its 8 pins/8 wires pics below ![]() ![]() ![]() |
![]() Join Date: Jan 2007
that has nothing to do with the fuel pump if that's part of your s14 engine harness
you could have a bad cam angle sensor, or it's not plugged in, or your ecu's no good, or it's not wired correctly. does the ecu turn on?
#3 | |
So the problem is no power going to ECU, hence why theres no spark and no fuel pump priming. Either something isn't grounded or a plug isn't plugged in, I don't know.
![]() Join Date: Dec 2002
That plug is for the EVAP canister harness going to the rear of the car. It has nothing to do with the fuel pump.
do you have a multimeter? start testing the ecu power/ground wires, that'll atleast narrow down your problem instead of "guessing" if the ecu is getting power or not. post up the results!
![]() Join Date: Jul 2006
I had the same problem when we were doing my swap and it turned out to be my cam angle sensor.. take it out and check the teeth see if they are worn. test your ecu outputs too like they said could be that.
95 SR Zenki | @ e_form daily - A34 Maxima | A36 Maxima |
like my friends killer said before, it worked before the oil pump change. it ran and everthing. we change the oil pump and now all the sudden no fuel pump prime or spark. when doing the oil pump change we did not touch anything on the harness or electrical at all except the cas sensor to get to the bolt below the cam (taht was bitch to get to). but i know we put in the cas right.
#9 | |
