Old 05-05-2008, 06:47 PM   #1
Ninjabread
Ninjabread's Avatar
Tie rod hits lower control arm
Does this happen to anybody? I just noticed today while swapping tie rods between two cars, that on one side the tie rod hits the LCA at full lock.
On my white(normal rack) car, this was the driver's side and on my red (hicas rack) car it was the passenger side.
White car has tein's and the red car has stock tie rods.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 05-05-2008, 07:02 PM   #2
Ninjabread
Ninjabread's Avatar
Maybe my rack is off center ?
When the wheels are straight, the steering wheel is mega crooked.
Used to be like that but not as bad.
I'll look into it tomorrow when I align the car.
613DriftWerks.ca
Old 05-05-2008, 07:13 PM   #3
Sil-Eighty SE-K
Sil-Eighty SE-K's Avatar
Sil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfectionSil-Eighty SE-K is close to perfection
Send a message via AIM to Sil-Eighty SE-K
mine does that with the tien inner/outers too.... It would go farther but the tie rod hits the LCA and thats as far as she'll go..... funny i just noticed that the otehr day when i was puttin on some drilled/slotted rotors and HAWK pads.... you could modify your front subframe to set the rack back farther so that the rods will be straight (will go even farther that way) and itll take more to hit the LCA if it even does at all.....
Originally Posted by JTunedMotorsports View Post
get off the thread...no one cares...
Sil-Eighty SE-K is offline   Reply With Quote
Old 05-05-2008, 07:14 PM   #4
Ninjabread
Ninjabread's Avatar
Ya, the funny thing is both my cars do it on opposite sides, with stock and with tein as well.
613DriftWerks.ca
