Old 10-30-2001, 03:54 PM   #1
Guest
Posts: n/a
ok well I've got magnecore wires and denso plugs, and I know those can add a few HP...but what about a MSD coil and ignition? Can that add an HP? What would be the advantage of having these and how much would it cost?
Thanks,
Chance
Also how much HP would an ECU add, and what are the disadvantages of having a Jim wolf ECU?  Better gas milage? Worse? The same?  Can it lessen engine life?
Thanks,
Chance
Old 10-30-2001, 03:54 PM   #2
Guest
Posts: n/a
i'm a dork.
Old 10-30-2001, 04:08 PM   #3
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
You're not a dork. Good plugs and wires will make an unnoticable difference. A good ignition system will give you MUCH better spark and your engine will run REALLY smooth. You'll notice a difference in idle right away. JWT ECU gives a few horses by remapping the air/fuel ratio and other stuff. It should give you worse gas mileage, if I'm correct. You can get an MSD ignitions for $319.95 (2 coil packs) or Jacob's Ice Pack for $324.95. The spark output is like a 15% increase.
Enuff info?
(Edited by S13Grl at 5<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wow.gif" border="0" valign="absmiddle" alt=':0'>9 pm on Oct. 30, 2001)
S13Grl is offline   Reply With Quote
Old 10-30-2001, 05:19 PM   #4
240sxtreme
240sxtreme is an unknown quantity at this point
Send a message via Yahoo to 240sxtreme
I'm not sure about the gas mileage thing on the JWT computer.....when I switched ecu's, I didn't notice any difference. &nbsp;maybe I'm an exception...anyone else have the JWT ecu?
240sxtreme is offline   Reply With Quote
Old 10-30-2001, 07:06 PM   #5
S13Grl
Married to the Mob
S13Grl's Avatar
Hey, I wasn't sure about it either, don't have one! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>
Old 10-30-2001, 07:14 PM   #6
konkman
konkman is an unknown quantity at this point
As for the wires and plugs, I found my Nology Hotwires did make a noticable difference above 5K RPM's (without platinium plugs).
From what I have heard about the performance difference of ecu's, for the money you should invest in more REAL sources of power, like a set of cams. IMO
konkman is offline   Reply With Quote
Old 10-30-2001, 08:24 PM   #7
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
It depends when you get the ECU. After you make a lot of changes, an ECU will give you a lot more.
transient is offline   Reply With Quote
Old 10-30-2001, 08:31 PM   #8
konkman
That's very true. &nbsp;I was refering, and I should have said this, to people starting off with upgrades. &nbsp;For the price of an ecu you could gain more power for less money with other mods, &nbsp;CAI is another good one.
Old 10-30-2001, 10:55 PM   #9
S13Grl
Married to the Mob
S13Grl's Avatar
I second that.
(See how nice I am, Konkie?)
Old 10-30-2001, 11:14 PM   #10
91CRXsiR
91CRXsiR's Avatar
91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self91CRXsiR is making a name for him/her self
Send a message via AIM to 91CRXsiR Send a message via MSN to 91CRXsiR
if you guys are running those turbo sil engines then you should really look into upgrade the ingnition system. dont want to lose power cuz of bad or weak spark.. i used plat +4 on my SC corolla .. i dont know what im running right now im my 240sx..
does it need plat? or copper?
91CRXsiR is offline   Reply With Quote
Old 10-31-2001, 12:44 AM   #11
IceTekGuy
IceTekGuy is an unknown quantity at this point
MSD ignition controller= 129.99$
IceTekGuy is offline   Reply With Quote
Old 10-31-2001, 12:47 AM   #12
Jeff240sx
I hate you too...
Jeff240sx's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from 91CRXsiR on 1:14 am on Oct. 31, 2001
</td></tr></table><span id='postcolor'>
I know for a fact that s14's need platinum. &nbsp;Well, it says so anyway.
-Jeff
Old 10-31-2001, 07:56 AM   #13
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
I've always heard that, with the exception of running the right plugs with the proper gap, wires and an aftermarket ignition would only start to help you when you were adding significantly more fuel and air. &nbsp;I've never seen a dyno plot that showed an hp increase from this mod on a basic-bolt-ons car. &nbsp;It's always someone's ass dyno that claims good results.
An ECU, on the other hand, is probably the best mod for the money. &nbsp;The factory tunes cars to run safe and efficient. &nbsp;An aftermarket ECU can be tuned to run at performance levels, rather than economy levels. &nbsp;Plus, you can have it mapped to maximize for the mods you have. &nbsp;That said, I would hold off on an ECU until I had the bolt-ons that I wanted so I could get them to tune it to provide me w/ maximum gains.
HippoSleek is offline   Reply With Quote
