![]() Join Date: Aug 2002
Just like the post says. How much is it normally to get it replaced?
Too many people use cars as an extension of their PENIS and they make me sick. A car is to get you from point A to point B or for motorsports. Not revving around town at stop lights. Check out my mods!: 50,000watt super amp and JDM lights!! Yeah right... S13 Silvia K's I got for free (I'm in japan now)!! Woot woot! '99 25GT-T Skyline (I don't want to list all the parts) http://welcome.to/skylinegtr '92 240sx HB |
E.G.R. valve I think means emission gas recirculation and it vacuums air back to the engine. It shouldn't be too expensive, problably less then 100, installation might be expensive. You should instal it it with somebody who knows about auto mechanic to save some money.
http://community.webshots.com/user/logo20 |
oh really? cause i talked to the mechanic and I asked him if it was the valve and he said it was the sensor. I didn't know there was an EGR sensor.
So it shouldn't cost too much to replace?
if it was like mine, the hose going to it is rubber and nissan had a great i dea of puttin a rubber hose on an EGR. it split,and was causing a real bad idle try replacing the hose first. before you spend $ on a new EGR
240sx s-13 TURBO weekend v-8 killer 90 Talon TSI WARNING.THIS CAR IS EQUIPPED WITH A TURBOCHARGER. DUE TO POSSIBLE BREATHING PROBLEMS UNDER HEAVY ACCELERATION, ALL FEMALES ARE ADVISED TO REMOVE ANY TIGHT FITTING OR RESTRICTIVE CLOTHING FOR SAFETY. |
Where is the hose that goes to it? I have no idea what it looks like or where it is <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> .
you know what my? damn idle is fukd too and its that EGR thingy. so replace the TWO hoses right? becasue there are two that go to the EGR right? should i remove the EGR valve and replace the hoses then put it back in? im not really used to the EGR valve part... holla.
silvia.. my love. fixin you piece by piece <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/inlove.gif" border="0" valign="absmiddle" alt=' ![]()
silvia... my love : ![]() |
I don't know. That's why I want someone to point it out for me <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sad.gif" border="0" valign="absmiddle" alt='
![]() Join Date: Apr 2002
From my deduction, the EGR system is located to the right of the engine bay. Yes, a hose from the EGR connects to the intake near the air filter.
Look to the right at the far end of the block; you should see a disk shaped valve with a hose running to a small black box, then to the air filter. Inspect those hoses. Good luck.
![]() Sleep Doesn't Drink Beer |
Thanks. I'm gonna go check it out in a bit. The possible problems with EGR in MOST cases are bad hoses or stuck EGR valve right? My engine only has 75k on it.
check out the back of the motor on pass side behind the fourth runner of the intake manifold, thats where my hose was cracked and split, i changed it and the idle shityness went away. i took the whole EGR out and cleaned it might as well while your doing it.
![]() Join Date: Feb 2002
I think the EGR sensor is the little sensor that sticks into the exhaust manifold. I have my stock EGR valve(the pipe that goes around the back of the engine as well as the sensor)off of my 93 KA24DE. I probably have the hoses too if you want em. Make me a reasonable offer and they're your's if you want them. [email protected] or pm me
~Ian |
#14 |
Yes, I look like that
![]() Join Date: Mar 2002
I went to my mechanic when my check engine light ccame on (the only time I ever go to a mechanic) and he plugged in and with the scantool, it came up "EGR level too high" or something to that effect and he looked at me and asked 2 questions.
Jim: Rough Idle? Me: Nope Jim: Bad fuel mileage? Me: Nope Then he clicked the button to clear the ECU and told me not to worry about it until I have one of those (or a similar) problem to go along with my check engine light... This was a year ago and I haven't seen the light since, <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'> |
#15 |
Cool, thanks a lot everyone. I haven't had time to check my engine yet but I'll keep you posted
#16 |
the manifold sensor is your o2 sensor... the egr is behind the intake manifold... mine had cracked to hell pipes and such, so I put new rubber in and my car runs fine.
sohc with 160k |
#17 |
![]() Join Date: Jun 2002
Im sure this has been anwsered but as far as I know there are both a Exhuast Gas Recircu-what ever Valve and a Sensor. The sensor pretty much tells you if its running correctly. this will probably effect your idle, but nothing to be scared about. It simply recirculates your exhuast gases back into the combustion cycle to be more "effeciently" burned.
I think
#18 |
I think the E.G.R. sensor is the one above the EGR valve. It looks like the EGR valve but smaller. Sombody told me once I had to chance it, this is important in passing the emission test.
#19 |
Man, I just popped my hood and the damn mechanic left a flashlight in the top right side of the engine bay. I tried looking for the hoses that go to the EGR and I still had no idea what it was and was not able to locate it.
Can somebody possible snap some pictures with a digicam or soemthing? that will be most helpful.
#20 |
if you will look at the exhaust manifold the is a tube that runs between the engine and the fire wall that connects to the egr valve it sould lead right under the intake runner closes to the fire wall.my 98 check engine light has been on for a year with the same problem its usually caused by carbon build up in the valve,damn light pisses me off
#21 |
its a silver disk shaped thing, like a flying saucer, with a hose going into it... its right behind the fuel rail on my 89.
and don't whine about the flashlight thing... its more like HEY! free flashlight! lol seriously what if that had went into the fan or something? stupid mechanic. |
#22 |
Hmm..., is it a rubber hose or a metal one? cause i remember seing a metal one but not a rubber one. Is it high like around at cover's level or lower by at level with the block?
#23 |
open the hood and look at the inside of the hood. there should be a diagram of the system. just follow that and you'll be very close to finding it.
I went to a shop and asked the guy where it was |
