Old 05-22-2008, 08:30 PM   #1
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
3 quick questions on 5speed swap details
1. Do I need to buy manual tranny flywheel bolts?
2. Do I need to buy the large steel "gasket" that goes between the tranny and the block (from a 5 speed car) or can I use the one on my auto motor?
3. Is the 5 speed brake pedal necessary?
Thanks
Fred
Fred Allen Burge is offline   Reply With Quote
Old 05-22-2008, 08:46 PM   #2
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
1. yes, manual tranny bolts are longer
2.not really,auto one would work. but i think the holes line up in different sections. but it will still work and fit.
3. no its not neccessary but only if you cut the brake padal. the auto one needs to be cut in order for the clutch pedal to fit.
hope this helps. goodluck with the swap.
chetacheese is offline   Reply With Quote
Old 05-23-2008, 01:48 AM   #3
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
1. yes u need em.
2. u dont need that plate thingy
3. no, i just cut mine and used the stock rubber piece to cover it up. looks stock almost.
gl on yours
lexus baby
5t341tH is offline   Reply With Quote
Old 05-23-2008, 06:51 AM   #4
Fred Allen Burge
Thanks guys, I appreciate the help.
Fred
Old 05-23-2008, 07:01 AM   #5
S14DB
AFC #1
S14DB's Avatar
2) You need the spacer/shield. Had a friend forget to install it when he rebuilt a motor and he swore he had crank walk cause the tranny input shaft was pushing on the crank.
But you really don't want road shit going into where the clutch is. Clutch and Flywheel get coated in crap, clutch slip.
Old 05-23-2008, 08:27 AM   #6
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
Thanks
Fred
Yes
Yes
No. Cutting the pedal takes all of 7 minutes. Then you slip on the pedal cover and call it a day. If you replace the pedal you have to drop the steering column, unbolt everything, wrestle it out of there, wrestle the new one back in, then bolt everything back up, re-adjust your brake pedal, blah blah blah. Too much work.
-Retired
98s14inaz is offline   Reply With Quote
Old 05-23-2008, 09:46 AM   #7
g6civcx
g6civcx's Avatar
Unless you can use a standalone clutch pedal and master cylinder setup.
Old 05-23-2008, 02:49 PM   #8
Zhanshi
Zhanshi will become famous soon enoughZhanshi will become famous soon enoughZhanshi will become famous soon enoughZhanshi will become famous soon enough
Yep, you need that shield. Reusing the auto one does not cover the bottom of the manual trans completely. So you will have road debris flying into flywheel/clutch area.
Zhanshi is offline   Reply With Quote
