Old 05-23-2008, 11:02 AM   #1
cleanest92
cleanest92's Avatar
cleanest92 is an unknown quantity at this point
clutch pedal sticking?
alright i got a 92 coupe and put a new clutch kit, master cylinder, slave cylinder, spring on the pedal, flywheel in it and its still sticking to the floor when i fast shift it. theres no air in the lines or anything. anyone got an idea for me?
cleanest92 is offline   Reply With Quote
Old 05-23-2008, 12:01 PM   #2
xsparc
xsparc's Avatar
xsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to beholdxsparc is a splendid one to behold
Send a message via AIM to xsparc Send a message via Yahoo to xsparc
hmmm... maybe its not adjusted all the way out? where does your clutch disenguage? top, middle, floor? when it sticks, is the clutch disenguaged?
I had a problem where the fork and piviot were all gummed up so it would sometimes stick like that.
Id say check the adjustment, fork and piviot.
No... no one stole my interior... its safely in my garage...
xsparc is offline   Reply With Quote
Old 05-23-2008, 12:38 PM   #3
g6civcx
g6civcx's Avatar
Also check the pedal return spring and the pedal bracket itself. Sometimes the bracket cracks and makes the pedal go sideway = stick.
Old 05-23-2008, 12:42 PM   #4
exitspeed
aWingThing.com
exitspeed's Avatar
Moved to tech section...
Old 05-23-2008, 07:23 PM   #5
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
I still think u have a faulty slave.... or not enough fluid.... might want to check if the slave cylinder is engaging and disengaging...under the car.... have a friend press the clutch pedal for u...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 05-26-2008, 01:16 PM   #6
cleanest92
cleanest92's Avatar
well it disengages towards the top and it sticks when its at high rpms. but if i dont get on the gas right away then it takes a second for it to pop back out. the slave works fine. i have no idea what could be wrong i just put a new line on it because the one had a kink in it. the guy im friends with that owns a trans shop says that the master cyl could be bad and to get one from the dealer? any other ideas for me.
