![]() Join Date: Nov 2007
manifold "vacuum" at idle should be 17-21 inches of mercury. yours says pressure so that would be negative 9.8 right? bad intake valves/vacuum leak? your short term fuel trim is rich that's why your short term fuel trim is -5.% you want those to hover around zero. O2 B1,S2: 680-740 mV i think bank 1 sensor 2 is bad. it should read min voltage of <200mv - >800mv but less than 1 volt. your range is way off thus your ecu is getting a mis calibrated signal and making you run rich.
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180 |
#2 | |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
The OBDII shows Manifold Pressure inHg...it's not shown as a negative number. I checked again and some cars show 9.8inHg at idle would be normal. I will recheck and use my brakes to see if this number changes properly. If it is a vacuum leak, where do I start looking?
Now my Kensai, I curse you to be a Ronin and with the my remaining spirit I, beseech Chimata-No-Kami, to have you wander through time and distance lands, seeking a new master. |
