Old 03-04-2003, 11:50 AM   #1
Apparition
Apparition's Avatar
Apparition is an unknown quantity at this point
Send a message via Yahoo to Apparition
What do I need? Clutch kit, etc.
Hey guys, I'm hooking up a 93' tranny to a 90' sohc engine. Already posted on that. But what clutch kit do I need, or they're all the same for 89-93?
1990 240sx coupe *sold*
Apparition is offline   Reply With Quote
Old 03-05-2003, 10:31 AM   #2
Apparition
Apparition's Avatar
Are the clutch kits different for SOHC and DOHC? Which one would I need? Probably the dohc cause its a dohc tranny?
Old 03-05-2003, 11:22 AM   #3
AKADriver
AKADriver's Avatar
yes, they are different.
it's the engine side (crank output and flywheel) that's different, transmissions are the same for the most part. So get the SOHC clutch.
Old 03-05-2003, 01:53 PM   #4
Apparition
Apparition's Avatar
Great! Thanks!
Old 03-06-2003, 01:17 AM   #5
Kookaburraz
Kookaburraz is an unknown quantity at this point
Actually, they're all the same, with a minor difference on the T/O bearing, which would have to do with the transmission side. It really doesn't make a difference though. ACT uses same for 89-90 and 96-98, with 91-95 being different, while Spec uses the same for 89-98.
Kookaburraz is offline   Reply With Quote
