Old 06-05-2008, 02:55 AM   #1
civilized_drifter
civilized_drifter's Avatar
civilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of lightcivilized_drifter is a glorious beacon of light
Send a message via AIM to civilized_drifter
KA could it be the head gasket?
i was driving home today and i went to give it some gas after i shifted into 4th and i had no power all of the sudden. i down shifted and gave it gas again and i tottaly lost all power and it stalled out. my friend was there with me and he checked the oil and he said that the oil is really thin as if coolant was mixed in it. i checked the spark plugs and they smelled like burnt coolent and oil and the tips were whitish brown. it started and idled until i give it a little gas and it dies. i got the car towed home and i checked the cylenders and i didnt see any coolent in there. when i wake up im gonna drain the coolent and see if there is oil mixed in there, the same with the oil.
could it be my head gasket? or is there something else that could be the problem? cause i have a spare rebuilt head and a head gasket for my spare ka and i dont wanna tear into this one if i dont have to.
civilized_drifter is offline   Reply With Quote
Old 06-05-2008, 03:06 AM   #2
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
By what you described...it does not sound like a headgasket problem.
Does your friend know anything about cars? or yourself?
How was your coolant? low? Check your oil cap, sludgy at all?
Might wanna double check and do a compression test to see how each cylinder(s) are holding up for security.
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline   Reply With Quote
Old 06-05-2008, 04:42 AM   #3
sliddinsil8o
sliddinsil8o's Avatar
sliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enough
Send a message via AIM to sliddinsil8o Send a message via Yahoo to sliddinsil8o
Same problem I had with the exception of thin oil and coolent issue...lost power going up a hill, down shifted to 3rd, no power...car died and I forced it to turn back on due to the fact that I was traveling at 50mph. But once it was at a complete stop it never turned back on. Point of this is that it ended up being a faulty injector...might want to look in that direction
****SIGNATURE EXCEEDS FORUM LIMITS....PLEASE READ THE RULES****
sliddinsil8o is offline   Reply With Quote
Old 06-05-2008, 04:52 AM   #4
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
leak down test.... first... make sure... then start from there.....
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-05-2008, 12:17 PM   #5
civilized_drifter
he has a fully built ka and yes he does. im gonna do a leakdown test and check the injectors
Old 06-05-2008, 09:07 PM   #6
sr20det drift
sr20det drift is on the path to ruinsr20det drift is on the path to ruin
i say do a compression test, and after you see your numbers, go on and test injectors, then test spark
sr20det drift is offline   Reply With Quote
Old 06-05-2008, 09:33 PM   #7
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
Another simple test that can pinpoint a problem cylinder is the balance test. attempt to hold around 2500rpm and unplug 1 injector at a time. each cylinder should drop the same amount of rpm when fuel is cut. If not than the cylinder with the least amount of change shows a weak cylinder for one reason or another.
RedtopTech is offline   Reply With Quote
Old 06-06-2008, 02:42 AM   #8
s13_maJiK
s13_maJiK's Avatar
s13_maJiK is an unknown quantity at this point
your oil wouldn't be thin and if there was coolant in it it would be milky
s13_maJiK is offline   Reply With Quote
Old 06-06-2008, 03:17 AM   #9
usajdm
usajdm's Avatar
usajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond reputeusajdm has a reputation beyond repute
+1 on compression test and injectors.
Not the head gasket.
What the hell is "BALLER" or "GANGSTER" status, about a 240sx?
usajdm is offline   Reply With Quote
Old 06-06-2008, 07:46 AM   #10
civilized_drifter
i would do that but my car dosent run. everytime i get it to start i give it gas it dies. last night i found my problem, the fuel pump isnt priming. when i get off work im gonna check to see if it is pumping
Old 06-06-2008, 07:46 AM   #11
HS13KLS
HS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant futureHS13KLS has a brilliant future
DUDE
i had the same problem..like 2 weeks ago..i thought i blew mine...execpt i was on the highway when i did it.
luckily it didnt stall there.anyways. i look off the valve cover and checked my valve train nothing was broken, and i dont think any rods or anything were hurt because im sure i would feel a sudden loss in power..i changed the oil...maybe 4-5 times with in 3 days.. and i checked the oil and it was perfect again, because mine was MILKY..looked like..well milk ha..
but if you need a headgasket i have a cometic one
HS13KLS is offline   Reply With Quote
