![]() Join Date: Feb 2002
![]() Hey guys..
This is weird.. I never had a problem with starting my car before. Yesturday, I parked my car in the drive way (on a slant, which is how the driveway is set up) and this morning, my dad moved the car, took his car out and parked my car in it's place. It was working fine. A few hours later, when I was getting ready to go to work.. I try to turn on my car, there is a spark but the engine never starts. When I put it on Battery, I heard a noise that I never heard before.. it goes "tktktktktkttktktkkkk" ticking noise and the "check engine" light is on. Very weird.. could it be my fuel pump? |
![]() Join Date: May 2002
open your passenger side kick panel (remove it)
unbolt your ecu leave it plugged in of course turn key to "on" (one click before the starting one) on the other side of ecu yo'll see a slot take a screwdriver (slot) and rotat the slot clockwise, wait 2 seconds go back counter clock wise read what it says (flashing lights) long bleeps are 10, 20, 30, 40 short bleeps (lights flashing) is 1, 2, 3, 4, 5 use that code to locate the problem but pull the ECU and start there. also check the engine and wires make sure everthing is cool we cnat help diagnose it if you dont do this first!!! you'll need a Philips, a slottted and a 10mm socket to take the ecu out to read teh code. takes 10 mins max |
oh sucks
yeah visual engine check. but you wont have any solid answers till u pull the ecu codes that will give you a straight shot to it being either the EXACT problem or a possibility of 3 - 5 different things it could give you a code thats something like "injector" and you know what your problem is exactly. |
![]() Join Date: Apr 2002
That is generally the sound that is made when your battery doesn't have enough juice to kick the starter over. The solenoid is trying to do its thing, but there is not enough current. With the temp at -40, I'd say it's time to either get it jump started and head over to a battery store, or just go buy a battery and put it in yourself.
Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
#6 | |
![]() Join Date: Jun 2001
Your car may not even take a jump start. My car started PERFECT for a year and a half, then one morning, tktktktktktktktktk. Tried to jump start it, it was still dead as could be. My battery had started to go bad, but my altenator was strong enough to still get the battery enough juice to start the car. That one morning, it went into a permanent slumber.
Lauren '91 300ZX TT Ultra Red 5-speed - JWT POPCharger, JUN flywheel, ACT clutch, Energy Suspension Bushings, Tokico Blues - dyno'ed 295hp/306tq '94 300ZX TT Black Emerald Pearl 5-speed - JWT POPCharger, JWT ECU w/ Stillen chip, Stillen exhaust, Tokico Blues, Eibach ProKits, 18" Enkei RP-01 wheels - dyno'ed 333hp/385tq '00 WS6 Trans Am Bright Red 6-speedFOR SALE - only 29k miles, stock, fully loaded, only $23,999 (NADA $26300) Green Country Motorsports Northeastern Oklahoma SCCA |
No no.. my battery is FINE.. It's a very faint ticking noise coming from.. um.. the fuel pump? I can turn on all the light, my car is starting but not jumping in.. its like its not getting gas.
#8 | |
Yeah I did, they all look fine.
The car just struggles to start, and no, weather is not the issue here I was exagurating, lol. My car has started in WAY colder weather before, andl ike I said, it was working a couple of hours before. |
Pearl White Mike
could be grinding/worn down teeth in the starter
most like its battery, get yeself an optima
"He who makes a beast of himself gets rid of the pain of being a man" ~ Samuel Johnson |
![]() Join Date: Nov 2001
When the starter solenoid gets real cold, it tends to do that. If it was just a battery problem or any problem with a battery connection, I would imagine it should be just one tick, not multiple. Turn the key and let it tick for like a dozen times. Keep repeating that until you've turned the key 10 times or so. The heat from the battery going through the solenoid for the startup might be enough to start car.
- Jared Edwards 3S Hybrid [img]too.big.jpg[/img] "Mandies, sandies, peppermint candies, we do it right and we drink a lot of antifreeze." - Group X |
Hey..
Well, I tried that, now the ticking noise is gone.. LOL, wtf happened? My car still wont start I gave it a boost, and still nothing, just struggles to go on.. lol, atleast that ticking noise is gone I'm having it towed to my mechanic, waiting for the tow truck now. Thankgod for free road side assistance |
