Old 06-10-2008, 06:27 AM   #1
tony96240sx
tony96240sx has made poor choicestony96240sx has made poor choicestony96240sx has made poor choicestony96240sx has made poor choicestony96240sx has made poor choicestony96240sx has made poor choicestony96240sx has made poor choices
sr20det swap...ac??
ok a friend of mines is putting a redtop sr20det engine in his 92 s13 240..do the lines from the KA engine line up with the sr AC? how can we make the ac work? thanks guys
tony96240sx is offline   Reply With Quote
Old 06-10-2008, 06:56 AM   #2
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Can either reused the KA compressor or cut and splice in the SR AC lines into the KA ones...
CLICK HERE!!!
Old 06-10-2008, 07:48 AM   #3
tony96240sx
wait so i can use the ka one..with what mods?
Old 06-10-2008, 07:53 AM   #4
fliprayzin240sx
You have to use the KA bracket, iirc, 2 or 3 of the 4 bolts will bolt up to the SR.
CLICK HERE!!!
Old 06-10-2008, 08:33 AM   #5
tony96240sx
he said he tried doing that but the ac compressor from the ka sits crooked and doesnt line up with the belts...now he is having problems with that and the driveshaft..can he use the same driveshaft froma 92.?
Old 06-10-2008, 08:44 AM   #6
fliprayzin240sx
Drive shaft should work, he just gotta knock the tranny boot off.
well if that dont work, Codyace has a groupbuy for spacers to fit the KA brackets and belt. Basically bolt the KA bracket, compressor and have everything line up properly...
CLICK HERE!!!
Old 06-10-2008, 09:02 AM   #7
flip3d
flip3d's Avatar
flip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond reputeflip3d has a reputation beyond repute
Send a message via AIM to flip3d
throw some washers on the compressor. it will line up.
flip3d is offline   Reply With Quote
Old 06-10-2008, 09:29 AM   #8
justaKAiswear
justaKAiswear will become famous soon enoughjustaKAiswear will become famous soon enoughjustaKAiswear will become famous soon enough
+rep he's right, you should be able to space it back a bit and get 3 bolts to line up. If you just use two, I could see a problem bucking belts
or, for $100-something buy the spacer and do it right and have all the bolts line up.
justaKAiswear is offline   Reply With Quote
Old 06-10-2008, 09:31 AM   #9
usdm180sx
usdm180sx's Avatar
If it's a redtop 3 of the compressor bolts will line up. That's all you need. You don't even need to disconnect the a/c so you don't need to discharge it either.
-Norm!
