Old 06-08-2008, 04:33 PM   #1
str8sidewayz
str8sidewayz's Avatar
str8sidewayz is making a name for him/her selfstr8sidewayz is making a name for him/her self
No Spark Pulse!!
i have a redtop s13.i have constant power n ground to my coils but no
pulse. i had the harness replaced and the car will not start. i was told either ignitor or cam angle sensor. i tested the ignitor but i wasnt even getting pulse from the ecu. can anyone tell me how else i can test the ignitor or cam sensor. HELP!
thank you..
Stage 1 weight reduction. Leaving your girlfriend home!
str8sidewayz is offline   Reply With Quote
Old 06-08-2008, 04:50 PM   #2
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
Have u checked ur main ground wire?? its under the fuse panel.
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 06-08-2008, 07:09 PM   #3
str8sidewayz
i will check that.. thank you. any other suggestions?
Old 06-08-2008, 07:18 PM   #4
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
prob the ignitor...
my car had 12v on the coils and they never pulsed.. turns out it was a bad ignitor
((sr)) kelly is offline   Reply With Quote
Old 06-08-2008, 07:32 PM   #5
GSXRJJordan
GSXRJJordan's Avatar
Yup, most likely a bad igniter. You can hook up a 'test light' to the CAS and see if it flashes, but first replace the igniter with a known good one, or see if yours works in a friend's car.
Old 06-08-2008, 07:34 PM   #6
WoolyS14DET
WoolyS14DET's Avatar
Trader Rating: (18)
WoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond reputeWoolyS14DET has a reputation beyond repute
Feedback Score: 18 reviews
Send a message via Yahoo to WoolyS14DET
UMM i think that the CAS sends the signal to the ecm which tells the ignitor to fire ?? Are you sure that the CAS is good ?? Or that one of the wires isn't cut/hooked up wrong ??
WoolyS14DET is offline   Reply With Quote
Old 06-09-2008, 03:00 PM   #7
str8sidewayz
thanks everyone for ur help.. im gunna try my ignitor on my friends sr. i appreciate everyone imput. ill let you guys know
Old 06-10-2008, 12:03 PM   #8
str8sidewayz
ignitor is fine i tested it in my friends car... i guess the only thing thats left is the CAS?? where can i find one 4 cheap? anyone know where i shud look,? i checkd on here i dint find much
Old 06-10-2008, 02:07 PM   #9
GSXRJJordan
No cheap CAS's. Sorry ~ you can try and find one used, or from an importer... otherwise it's $tealer$hip.
