Old 06-14-2008, 07:59 PM   #1
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
SR driveline: what's going bad?
The car had been fine up until ~2 months ago, when we took it on a road trip to Baltimore, ~250mi each way. A couple times on the way back, I would get this wicked bad tranny whine: I'll be driving, and I'll put the clutch in, and the tranny starts whining/groaning really loud. I put it in neutral and it stops, and won't do it again when I put it back in gear. It's happened sporadically since the road trip, and I think it's getting more frequent.
What's up?
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 06-14-2008, 08:08 PM   #2
WagDatto
WagDatto's Avatar
WagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfectionWagDatto is close to perfection
Send a message via AIM to WagDatto
Tranny or could it be diff related? Check/replace your diff fluid, it might be whining, sending vibrations up the driveline to the tranny (which is partially in your car, maybe that's why you'd be hearing/feeling it there?).
Might as well do it anyway, fresh diff fluid is never a bad thing. You checked gear oil in the tranny lately, too? Might need to be topped off/replaced?
Just tossing out random "in front of your face" answers, since it almost always seems to be the easiest problem when you can't figure it out.
http://garagezoku.blogspot.com
WagDatto is offline   Reply With Quote
Old 06-14-2008, 08:16 PM   #3
SHIFT_*grind*
Gear oil went in ~4 months ago, 2.5 qts I think. I hope it's not leaking...
Hadn't though about the diff.
Old 06-14-2008, 09:13 PM   #4
WagDatto
WagDatto's Avatar
It's probably not the diff, though it could be the subframe, bushings, etc.... I'd think that any kind of vibration in the driveline would transfer through the tranny/gear shift and be noticable to the touch and to hear.
Old 06-14-2008, 09:25 PM   #5
S14DB
AFC #1
S14DB's Avatar
Input(pilot) Bushing most likely.
Old 06-15-2008, 01:16 AM   #6
waterboy
waterboy's Avatar
waterboy can only hope to improve
pilot shaft bushing if its a high pitch sound
waterboy is offline   Reply With Quote
