![]() Join Date: Mar 2004
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
California Smog/Emissions Test Failure, High HC
I'm in California, so you guys here will know the drill. I'm a test-only bitch of the state, and so I'm kind of limited in my options here. As I'm also limited in funds for sending it to a Test and Repair shop, I thought I'd come here first.
Here's the gist: 1990 Nissan 240sx, swapped SOHC for a 91' KA24DE. Roughly 200k miles on the clock (didn't write down from donor car). What I have, asterisk (*) indicates new since failure New Catalytic Converter *New Spark Plugs (NGK Platinum, properly gapped) *New Plug Wires (Bosch, I know, I know...) New Rotor and Cap *New Injector O-Rings (Nissan OEM, not 3rd party) Injectors all test within spec Compression 149 +/- 2 across the board Not burning any oil that I can detect Timing set 15 degrees BTDC as I heard that helps with HC. I was told I had a slight misfire at idle, which is why I've changed the above components. Now, for the numbers @idle (650 per fsm) %CO2 14.9 (Pass) %02 0.2 (Pass) HC PPM 169 / MAX=120 (FAIL) %CO .11 / MAX=1.0 (Pass) @2500~RPM %CO2 14.7 (Pass) %02 0.3 (Pass) HC PPM 72 / MAX=140 (Pass) %CO .37 / MAX=1.0 (Pass) So... any ideas? |
#10 | ||
I've seen that stuff, but always felt kind of wary about it... I've got the time, so I guess it couldn't hurt. I'll think about it. |
Check out my response from a previous thread.....
http://www.zilvia.net/f/showthread.p...highlight=smog Put your ECU into Diagnostic Mode & check for any trouble codes. Make sure your Engine Coolant Temperature sensor is working along with your Oxygen sensor. Also check the small vacuum line under the BPT valve. It's "L" shaped and usually cracks causing a loss of vacuum to the EGR valve. Hope it helps... ID EDIT: Damn CARB!!!...they went & changed the link on me!!!....this is the CORRECT CARB link.... http://www.bar.ca.gov/80_BARResource..._Glossary.html
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies.... ![]() |
#12 | |
Code 55, all clear. Did that earlier today. That specific vacuum line was cracked a month or two ago, I replaced it. Will check again. 02 and CTS are both under 3 months old and tested good when installed, but again, I can check. Haven't looked at your links yet, will do in the morning when I get up for work. Thanks again, to everyone really. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
for an easy fix, create a small, not very noticeable vacuum leak. since you are not in an enhanced area, you dont need a dyno test, and NOx is not measured. just make sure its hard to find.
#15 | |
Sky blue? Never heard of it. I've done the Seafoam thing before, but this is new to me. |
#17 |
![]() Join Date: Jun 2007
Oh yeah, full your take up like, 3/4 the way, then pour in some everclear...
Seriously, get some uh... Seafoam. Thats it. couldnt think of the name. It'll clean up your engine real good like, tell you what boy.
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
#19 |
Use a quart of denatured alcohol. Search around the net. This stuff works. My car failed the sniffer horribly and with the alcohol I passed with flying colors with no cat. I repeat with no cat. I have several friends that have passed with their SR and RB powered cars with no cat. Just run you fuel down to 1/4 tank and pour the alcohol in run it hard for a few miles and go get it tested
