Old 06-18-2008, 10:12 PM   #3
ziptiedae86
ziptiedae86's Avatar
ziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfectionziptiedae86 is close to perfection
yeah there are 2 screws behind each headlight one for lateral (left and right) and one vertical.
look at the headlight you think is aimed properly and note where the air bubble is on that side, then adjust the vertical screw (8mm wrench) until the air bubble is in the same position as the other side. you can adjust the left right by using the other screw NEXT to the one with the LR directions on it. both the low and high beams are adjusted together.
really not too difficult at all lol
gl
ziptiedae86 is offline   Reply With Quote
