Old 06-22-2008, 10:07 AM   #1
BustedS13
BustedS13's Avatar
well great. whitish smoke all the time.
the setup. my car hasn't run in about three years. we pull the engine, replace the clutch, replace the IACV, remove the EGR and AIV. put it back together. start it up. NOTE. i had pulled the harness to clean it up, and in the process cut off the old frayed and nasty o2 sensor plug. i forgot to put a new one on, so when we initially started it up, the o2 sensor was not connected. and it stumbled a bit, but it idled and didn't smoke.
so today i go in and put on a new connector and hook up the o2 sensor. everything seems cool. but then i take it for a drive, and about a block down the road, it starts smoking like mad. smokescreen of thin whitISH smoke. not pure white, not thick. i bring it home and let it idle, and it's more of the same, albeit not in the same volume.
any ideas? please tell me i don't need to pull this engine again. easy fix, guys. please.
Old 06-22-2008, 10:08 AM   #2
Ninjabread
Ninjabread's Avatar
Maybe just residue in the exhaust or something
If it smeels sweet, its coolant
blue tint to it its oil
was it overheating?
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 06-22-2008, 10:13 AM   #3
BustedS13
BustedS13's Avatar
was it overheating?
it doesn't smell sweet, it might have a bluish tint to it. and it's not overheating
Old 06-22-2008, 10:15 AM   #4
Ninjabread
Ninjabread's Avatar
Probably dry valve seals
my motor sat for 2 years before i installed it
and it used to smoke when you started it / sometimes for a while while you drove.
I was too lazy to do anything about it, i just always toped up my oil, but it didnt burn much
613DriftWerks.ca
Old 06-22-2008, 10:23 AM   #5
njd07
njd07's Avatar
njd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfectionnjd07 is close to perfection
Send a message via MSN to njd07
does it smell like gas?? prolly running pig rich
njd07 is offline   Reply With Quote
Old 06-22-2008, 11:04 AM   #6
BustedS13
BustedS13's Avatar
it kinda smells like gas. but that might just be my mind shutting down and demanding a simple solution.
