Old 06-22-2008, 01:24 AM   #1
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
starter relay (i already searched but i failed)
i already search where i can find the starter relay/inhibitor relay. i already searched the forum for any info about it but i cant find any what i need. i have a chilton book and i already looked at it but it seems like it has missing details too. so can anyone show me where to look for these relays?
thanks in advance.
Old 06-22-2008, 02:15 AM   #2
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
is your
http://forums.nicoclub.com/zerofile/37775/000_0990.jpg car automatic or 5 speed. automatic is called inhibitor and standaard is called interlock. per the link, inhibitor is in relay box by battery
surreybc is offline   Reply With Quote
Old 06-22-2008, 09:11 AM   #3
g6civcx
g6civcx's Avatar
I'm a little unsure about what you're looking for. What are you looking for?
Like said above, there are different things going on: clutch interlock switch/relay, inhibitor switch, starter solenoid, ignition switch and relays.
What are you trying to do?
Old 06-22-2008, 10:16 AM   #4
projectRDM
projectRDM's Avatar
Autos don't have a relay, just an FYI.
FORMERLY R240NA
Old 06-22-2008, 12:49 PM   #5
surreybc
autos have different wiring for starter but have an inhibitor
relay
http://img293.imageshack.us/my.php?image=img0030qr4.jpg
Old 06-22-2008, 01:52 PM   #6
wangan_cruiser
kouki man
Trader Rating: (36)
facts : new starter from autozone
my starter clicks but the motor doesnt work. but when run a direct to the 2nd bolt next to the motor. the motor works. im troubleshooting my line for any worn out connections. thats why im trying to look for the main location to look. thanks in advance.
Old 06-22-2008, 02:45 PM   #7
projectRDM
projectRDM's Avatar
relay
Again, it's not a relay, just a two position switch. Open or closed.
FORMERLY R240NA
Old 06-22-2008, 02:46 PM   #8
projectRDM
projectRDM's Avatar
Bypass the starter relay, take the two large gauge wires and tie together.
FORMERLY R240NA
Old 06-22-2008, 04:59 PM   #9
surreybc
Are you sure the starter is clicking and not some other relay? You should get a multimeter and test to see if your starter solenoid is getting power from the ignition switch. you can unplug the connector for small wire coming into starter and test to see if it is getting 12 volts. check the clutch interlock switch on the clutch because that is the most frequent cause of problems.
follow this troubleshooting guide. you dont have to hit starter because it is new. bad battery and clutch switch are most common problem
there is a pic that shows location of ignition wire at starter which should be tested for 12 volts
http://forums.nicoclub.com/zerothread?id=249966
Old 06-22-2008, 05:01 PM   #10
surreybc
there is an inhibitor switch and and inhibitor relay. it is even labelled inhibitor relay in fsm.
