Old 06-02-2008, 03:53 PM   #1
dk_fabiosantos
dk_fabiosantos's Avatar
dk_fabiosantos is an unknown quantity at this point
wheel adapters
I am looking for an adapter to install 5 lugs 5x100 rims onto 5x114.3 spindles.
This is what I have: I have a volks rims that says 5x 114.3 in the back but it won't fit my skyline 5x114.3 the rims seems to be wrong pattern,so, I need adapters to install them on my skyline.
Anyone has it for sale?
Let me know!
Thank u very much.
dk_fabiosantos is offline   Reply With Quote
Old 06-02-2008, 04:18 PM   #2
A Spec Products
A Spec Products's Avatar
Are you sure?
If there is 5x114.3 stamped into the back of the wheel (and not the casting bolt pattern mark), I think its HIGHLY unlikely that Volk drilled the wrong bolt pattern for the wheels
Also, keep in mind that conversion bolt adapters aren't the best of methods, and also, it will change the offset of the wheels you have, because a conversion spacer will need to be at least 20mm to be safe (at least to me)
A SPEC PRODUCTS CORP
Old 06-30-2008, 05:14 PM   #3
cisco240
cisco240's Avatar
cisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud ofcisco240 has much to be proud of
What kind of Volks are you referring to? I have a set of Volks that have that same problem. Says 5X114.3 on the sticker w/ all the info on the wheel, but they are actually 5x100. Just to make sure I wasn't crazy, I got a set of adaptors for 5x114.3 to 5x100 and bamn! It works. WTF!
Originally Posted by 96Turbo
dude. subject, verb, & then motherfuckin predicate. ya dig??
cisco240 is offline   Reply With Quote
