stripped sr20det block
hey everyone well i was changing some gaskets on my turbo and i went to re-install my turbo and did everything right but i fuckeed upppp
![]() ![]() should i use a re-threadding kit? which i already have bought it at carquest or should i just make it bigger by using a bolt from the coolant line of the turbo it'll work we were checkking it out... any suggestions or ways to fix this problem will be much appreciated thanks... Last edited by JRwerks; 06-30-2008 at 08:24 PM.. |
![]() Join Date: Jun 2007
If you rethread it, all those metal shaving will get into the oil. You might as well drop the pan and clean it up real good, just to be safe.
Better safe than sorry.
BRAND NEW GReddy PRofec E-01 EBC for sale, Cheap! |
shittt i was re threading it and now it broke off lmfao suxxxx so now i gotta pllug up the whole where the oil hardline bolts on tooo and now im getting a sandwhich plate for it ill juss run my turbo oil line threw there....
any ideas what i should use to plug up the oil whole with??? |
Im Just Wondering Will It Be A Good Idea To Use A "sandwhich Plate" I Think Thats My Only Solution Now... What Will I Need Besides The Sandwhich Plate And Steel Braided Lines...?
![]() Join Date: Aug 2007
i did the same thing.
what I did was kinda complicated, but it worked very well for me. I rethread it with a bigger size. And put a female to male fitting in there. The male side of course goes into the block. Buy a male to male fitting that fits the female side of the fitting on the block. So now your block's got two fittings if you still follow me. I bought some stainless steel line from ATP turbo. and buy another fitting or oil restrictor (male to male) to put on the turbo. Now both the block and the turbo have the male fitting. And the stainless steel line from ATP has both ends female ends. And connect them. Dont forget to apply some thread locker, too. That sounds complicated, but actually it is not that complicated, and it works just fine. lmk when you have any question |
![]() Join Date: Jan 2008
![]() Feedback Score: 14 reviews
i used a sandwhich plate for my sr20 before works great same problem..
NEED S14 KOUKI VALANCES, S14 NAVAN SIDE SKIRTS, S14 KOUKI OEM JDM LIP HIT ME UP!! Last edited by gunmetalr32; 06-30-2008 at 08:20 PM.. Reason: correct |
yea that would have been a good idea thats what i was trying to do but juss re threading it with a bigger bolt but the whole side piece where u screw the fitting in broke off so now u cant screw anything in the block..
