cometic headgasket question reuse?
ok so I recently built my motor and now i've ran into some problems with seating the rings. Long story short I'm tearing her apart again. I'm wondering if i can reuse the metal cometic headgasket or do i have to buy another one? I've heard they come in only one size of bore and i am currently stock 86mm now and will be boring out to prob 86.5mm so I'm wondering what i should do?
I have all arp studs so I should be fine there and i'm going to buy a gasket set. The HG has maybe 4000kms on her.... thanks for your help chris |
Well i have heard horror stories about the apexi ones aswell. I am just wondering if anyone has reused them before as i would assume it should work but I'm only assuming here.
thanks chris |
![]() Join Date: Jun 2008
nope never tried...i'm using the greddy metal one right now and it MAY be causing a compression problem...but i'll have to get back to everyone on that. hopefully i fixed the issue this past weekend. but yeah, in the future i'm def going oem.
#6 | |
![]() Join Date: Jul 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
OEM???.. are u crazy? yeah good luck with a paper head gasket pal you can reuse a cometic head gasket as long as its not warped or broken or whatever. i have done this many times with no problems. however i have had problems with a HKS head gasket.
![]() Join Date: Dec 2003
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
this thread just made a bunch of people go.
FUCK! Which one do I get??????? HKS....sucks Apexi....sucks Cometic....sucks Greddy....so far good Tomie...so far good stock....FTMFW (apparently) ![]()
Fu*king ginger bread man stole my wallet... SHIFTlock_slide to side d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson |
Yea I am kind of confused now, because i was going to buy a cometic HG for my ka24de rebuild. Now I'm not so sure. Can some one shed some light on this please.
Trader Rating: (22)
see^
I used JB weld and it seems to hold up. haven't driven it yet tho! 500rwhp here I come!
tell us how it runs
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
Usually the horror stories on the cometic are from ppl who either never had the block and/or head sent out to a machine shop to get them perfectly even or never torqued the damn thing down properly. Sure there are always those who do everything by the book and beyond and still end up with a leaking headgasket, but I feel that every manufacturer sends out a lemon sometimes.
- Jimmy Wanted: TBD For Sale: TBD |
#14 |
Trader Rating: (54)
Also, don't be afraid to ask what cometic recommends to torque down the sucker at. If I remember correctly it might be 10-20 lbs/ft more than OEM.
#15 | |
![]() EDIT: Do you think they might put the specs for how much to torque in the packaging?
#16 |
Trader Rating: (54)
I would guess they would or just tell you to follow factory specs, but I'd rather hear it from someone who works for the company and have his name on paper with the time and date I spoke to them incase shit hits the fan. Being cautious never hurts when building an engine
#17 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 3 reviews
i have an apexi one with my 2.35L sr and i dont have one problem with it. i also have been boosting 20 psi on it.
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE! 10.79 @ 124 MPH WITH A 1.48 60' |
#18 | |
![]() Join Date: Sep 2003
![]() ![]() ![]() Feedback Score: 1 reviews
PS: Multiple people have used felpro head gaskets up to around the 400hp range.
'96 Nissan 240SX KA-T ─ '05 Grand Cherokee Laredo 4x2─'85 Nighthawk |
#19 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
as with any metal h/g its recomended to resurface cyl and block.
ive used a TRD h/g in my ae86 and i currently have a cometic h/g in my built 4ag running 12:1 comp and it does fine. dont reuse |
#20 | ||
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
If it was me, I wouldn’t bother taking the chance of reusing it, I’d just buy an Apexi and call it good, but it really depends on how much your time is worth to you. For me, when it comes to anything inside the motor, I’ll spend all the money it takes to try and make sure I don’t have to open it up again (I’ve done enough of that).
#21 |
![]() Join Date: Jun 2004
i have a ka-t boosting 12-14psi daily. ive been running the cometic head gasket for 1 1/2 years without any problems. it did, however, leak when i started up my engine for the first time. but after that it was fine
#22 |
i've used power enterprise 3 times over and still no problems... no gasket maker crap needed. my buddy put together a 500whp sr20... took it apart once still no problems and he beats the shit outta his motor...
lil bit more pricey but def worth the peace of mind. better cooling with the gasket too!
No MORE S13!! SC300!!! ![]() |
#23 |
![]() Join Date: Apr 2004
![]() ![]() Feedback Score: 6 reviews
Cometic head gaskets can be reused again and again; I remember when I worked at Kintner's an old mustang shop in southern Indiana we reused Cometic head gaskets again and again on the shop racing motors and those were 16.5:1 nitrous motors putting out well over the norm even if you cut that power in half for just 4 cyl. I currently run a cometic hg in my SR and have for over 3 years at 19lbs. w/FPbig28, cams, etc. and had no problems whatsoever.
Also a friend of mine has reused his cometic HG 5 times in different H22's over the years from high compression nitrous set-ups to his latest turbo set-up. The biggest factor is proper block and head preparation; Make sure the edges are sharp and the hashes are present in your prep-work and use your common sense does that hg look like it will seal again, is there still springiness to the steel, is it screwed up from improper installation the first time? Etc. |
