Old 07-18-2008, 09:27 PM   #1
bunnathp
bunnathp's Avatar
bunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of lightbunnathp is a glorious beacon of light
Send a message via AIM to bunnathp
Question q45 caliper rebuild help!!!
ok. so i have a set of front q45 calipers that i plan to put on my s14. and since theyr old calipers, i just bought a rebuild kit. but the thing i dont know what to do with teh rebuild kit. can anyone post any instructions? i tried searching but i only found that one thread about rear calipers and it being r32 calipers or whatever. help would be greatly appreciated. thanks guys.
bunnathp is offline   Reply With Quote
Old 07-18-2008, 09:32 PM   #2
SoguRacing
SoguRacing's Avatar
SoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfectionSoguRacing is close to perfection
Send a message via AIM to SoguRacing
i'll do it for you if you have all the parts/supplies. i dont feel like typing a lot
Pre Tune Checkup! Compression,LeakDown,Vacuum Test $80. Cams Install: $180
SoguRacing is offline   Reply With Quote
Old 07-18-2008, 09:34 PM   #3
bunnathp
bunnathp's Avatar
lol thatd be awesome =) i have the calipers and rebuild seals. but what else do i need? i have tools. i dont have an air compressor though.
Old 07-18-2008, 09:40 PM   #4
SoguRacing
SoguRacing's Avatar
i have a compressor. do the pistons have scores on them? and how about the piston walls. take this to pm.
Old 07-18-2008, 09:44 PM   #5
96Turbo
96Turbo's Avatar
96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute96Turbo has a reputation beyond repute
it comes with piston seals and boots. basically the seals go inside the piston bore and seal against the piston (just a rubber ring basically)
The boot is the rubber part thats visible. It keeps dirt and shit from getting inside the sliding part of the pistons.
rip off the old boot, stick your air compressor (if you had one) in the brake line hole, and pop out the old pistons. then pry out the rubber rings...clean the shit out of everything...
and reverse this process. lube everything up with brake lube, and you're good to go. sometimes the boots can be a bitch to get on, but with enough persuasion from a flathead screwdriver and working around them with your fingers they'll snap on.
PS get the rebuild kit from autozone....by far the cheapest i could find
peace
96Turbo is offline   Reply With Quote
Old 07-18-2008, 09:50 PM   #6
bunnathp
bunnathp's Avatar
thats where i got it =) autozone ftw.
Old 07-20-2008, 03:55 PM   #7
ranger2339
ranger2339's Avatar
ranger2339 has a spectacular aura aboutranger2339 has a spectacular aura aboutranger2339 has a spectacular aura aboutranger2339 has a spectacular aura aboutranger2339 has a spectacular aura aboutranger2339 has a spectacular aura about
Send a message via Yahoo to ranger2339
Nice thread Im about to do the same thing to my Q45s.. does the kit come with the boots for the bolts? The little boots?
ranger2339 is offline   Reply With Quote
Old 07-20-2008, 06:37 PM   #8
96Turbo
96Turbo's Avatar
nope, thats a separate kit.
its called something like "slide pin bushing kit" or somethin similar
I had to replace one of mine too
Old 07-20-2008, 07:26 PM   #9
ranger2339
ranger2339's Avatar
Ya I'll be getting them both, anybody have any part numbers for the Autozone kit? For both if possible?
Josh
Old 07-20-2008, 10:39 PM   #10
96Turbo
96Turbo's Avatar
usually i'd say find them urself lazy ass...autozone's website isn't all that complicated
but since ur from MN i got ya back
Rebuild kit - 66373 - $4.99 each
Bushing/Pin Kit - H16005 - $7.99 each
Old 07-21-2008, 01:48 AM   #11
bunnathp
bunnathp's Avatar
yepyep. i made a mistake and bought only one kit when i had two calipers. make sure you buy one kit per caliper. best of luck to you. =)
Old 07-21-2008, 02:32 AM   #12
importdude
importdude's Avatar
importdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond reputeimportdude has a reputation beyond repute
Send a message via AIM to importdude
i did the same thing
importdude is offline   Reply With Quote
Old 07-21-2008, 02:49 PM   #13
ranger2339
ranger2339's Avatar
Ha you the man ,thanks bro.
Josh
