![]() Join Date: Jan 2008
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 6 reviews
Magnetic Drain Plugs
This is a copy-paste article from jdm-insider.com
I thought it was a very interesting read. While searching for key words, I found some threads with people asking about them, so.. "Somebody forwarded this email to me today where this new company, Titek, was promoting their magnetic drain plugs for an engine’s oil pan. While the concept is somewhat novel, it’s application is kind of dumb. A magnetic drain plug (mdp) has its place in a transmission with steel gears or a rear end with steel gears and metallic clutches where bits of steel can actually float around in the oil. However, a mdp actually has no place in an engine’s crankcase if you really think about it. In the remote possibility that your engine’s cams are gear driven, an mdp might have a place, but chances are if you are reading this blog your engine does not have gear driven cams. Let’s think about what’s inside of an engine block for a second here: a crankshaft, bearings, rods, pistons, wrist pins, pin clips, and piston rings. The crank, rods, and pins are all riding on films of oil. The pin clips hold the wrist pins in place and the piston rings are held in place by the piston’s ring lands and neither bits of clips or rings can come out unless a catastrophic failure occurs. In the head, you have cams, followers, springs,retainers, and locks. If any of these components fail, the last thing you need to be worrying about is catching bits of steel at the very bottom of an oil pan with a mdp. So in a healthy engine, what’s the purpose of having a mdp? The only components that can wear are the bearings and at that point your engine has become unhealthy probably due to a cracked oil pump rotor, oil pickup tube, lack of oil or pump cavitation and is living on borrowed time anyway. Bearings consist of lead, tin, copper, and sometimes babbit and/or aluminum. The last time I checked, none of these elements were magnetic because they are non ferrous. If the steel components break (crank, rods, pins, clips, or rings) or chip, the last thing you need to be worry about again is catching bits of steel at the very bottom of the oil pan with a mdp. You will more likely be either on the side of the road or track with a hole in your engine block and waiting for a tow truck. No mdp no matter how strong it’s magnet is, is going to save the day. While technically it cannot hurt to use an mdp on your engine’s oil pan, it has no merit either. I’m not bagging on Titek since I know nothing about their products and I’m sure there are other companies that make mdps. I’m just making a point that mdps are useless. Some companies like to make products to increase sales so you can spend your hard earned money. That’s ok, but spend it on something that’s worth a shit." http://jdm-insider.com/Blogs/Eric/?p=889 |
Hmm I don't know about you guys, but when I do an oil change theres usually a small cluster of metallic particles attached to my drain plug, so I consider it to be helpful.
#3 | |
![]() Join Date: May 2004
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
Subsequent oil changes almost nothing, but still tiny specs here & there.
bew bews! |
#7 | |
AFC #1
![]() Join Date: Oct 2003
Steel is the only ferrous metal? Damn, if those Iron sleeves in your block wear...
I've noticed the magnetic drain plugs are more effective on your tranny.
Plus do NOT order the PWJDM ones. I bought 2 sets for my civics, and one set when I pulled apart the magnets, one of the magnets came out of the socket. (the 2 drain bolts attach themselves together in the packaging) Held on by a very thin elmers green colored goo. I then pulled all of the magnets apart and JB welded them back in, let them dry for 2 days, sanded the jb weld down, applied another coat. Did that 3 times. Dont want a magnet walking up the crank |
#12 | |
please elaborate. i have a power enterprise filter, and it comes with a magnet. should i be worried? ![]() |
![]() Join Date: May 2006
Your oil does pick up metal from wear on you engine. I've had a Project Kics Mag drain plug for two years now and every time I open it it has a very small residue on it(it's not oil either). So whatever magnetic particles it picks up it stays there instead of circulating around in your engine/turbo. Better safe than sorry IMO.
#15 | |
![]() Join Date: Feb 2007
I have one of these mdp's and when I change my oil there are metal particles stuck to it. Particles that would other wise be working their way around engine and possibly causing damage. The point I am tring to make is; this email and it's content is misleading. The author sounds intellegent, but in fact his reasoning is weak: -Transmissions need magnetic drain plugs because they have gears and gears on gears wear making metal debis. -Engines don't have gears, so there is no wear, so no need for a magnetic drain plug I am not saying that if you don't have one you are going to die, rather that they are not as usless as the OP seems to suggest |
#16 |
![]() Join Date: Jun 2006
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
Plus it doesnt hurt to pay only $10 for a plug..its not like fuck i just spent a couple hundred and it doesnt even work..plus when I do an oil change..yup..metal particles are there a little bit..
Driftphreak87 |
#17 |
![]() Join Date: Apr 2004
My brand new GM crate engine is as "healthy" as a motor can be. Every time I take off the magnetic drain plug, I see a lot of metal particles accumulate on the magnet.
Every one of my car has a magnetic drain plug, and every time I pull the plug I see some kind of debris. If they all come out clean then I would consider not buying magnetic plugs again, but based on my personal experience I will continue to use them. |
#19 |
dude the magnetic drain plug in my diff saved me when my welded diff exploded because the big pieces were caught so the magnetic drain plug can save you in a worst case scenario.
#20 | |
Your comment is not germane to the discussion because we're discussing engine oil pan drain plugs, not diffs. |
#21 |
![]() Join Date: Mar 2002
Honestly there's lots of impurities floating around. From your engine to your engine oil. Yes your engine oil does contain some. It's not a perfect world but we can try to minimize the ill effects with some band aid fixes here and there. I would also like to know how filter magnets are creating problems?
Bigsyke, please provide some evidence of all these harmful claims/situations.
Go big or go home! |
#22 | |
A good quality MDP does the same thing everytime you turn the car off, and is $30 cheaper, and would no way affect bypass pressure. It catches the particles before they hit the pickup/filter further lengthening the life of a filter on initial start up. |
#23 |
LAID OUT
![]() Join Date: Mar 2004
Every time I've ever pulled out a mdp, it has metal particles on it. It just grabs some of the bigger crap before the filter can get it. Who cares, they're super cheap and add marginal additional pre-filtering abilities...
#24 |
not giving a fuck
![]() Join Date: Apr 2007
Trader Rating: (104)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 104 reviews
i just like em because i dont have to fish for the plug in my drain pan...all i need is a wrench and no oil burn for me LOL
![]() ![]() PSN & XBL GT : Wh0pp3r68 CLUB LEXUS : Wh0pp3r ![]() |
#25 | |
If you do it right, you should have no oil on your hand. It may also help if you hit the plug with some compressed air or brake cleaner before you touch it so you don't burn yourself. Some people can do it just the socket and never having to touch the plug with their fingers, but that's too much manual dexterity for me ![]() |
#26 |
why not get a pair of latex gloves on, and wait for things to cool down? I love the concept of a hot oil change, but what justifys building oil pressure quicker vs having a proper lb/ft reading and a good seal?
I think the moral is MDP's are great, dont do ANY harm ~ as long as it wont fall out of the drain plug. |
#27 | ||
I agree. Oil causes cancer.
#28 | |
The filtermag would have to be pretty close. Less than an 1/8" away from the bypass spring... It's possible to worry if it was such a small filter, that the magnet surface area somehow the filter just took up the whole area.. or if the magnet moved around, but that actually doesn't happen. Once it's stuck on there, it shouldn't be attached anywhere near the bypass spring and it's stays put, but yeah, your claim is substantiated by anything other than assumptions. Just FYI, I have rebuilt a SR with a filter mag and haven't had issues as of yet and prior to this I had a rebuilt KA motor. I wouldn't go as far as badmouthing it without any actual experience. ![]()
#29 | |
not giving a fuck
#30 | |
Im saying I wouldnt myself get one for my own reasons. I change my filters enough to not have to worry about metal shavings in the filter. The price offset isnt worth any potential trouble it COULD make. Myself am a believer that any metal shavings flowing across such a highly magnatized area could magnatize the particles themselves. I have an mfactory magnetic drain bolt. That thing could fish out particles in your oil like you couldnt imagine. I tried putting some metal shavings in a bucket, the MDP does a fine job, and id rather opt for an amsoil Eao filter |
