Old 07-22-2008, 03:43 PM   #15
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
first is it a base or SE?
2nd, all you need to do is connect the starter wires together, and ignition wires together. I had the same issue with my s14, but it sounds like the alarm is still armed- OR, they just yanked the brain out. Pull the fuses out of the alarms fuse holders, if the LED is on because you pulled the neg terminal that means the kill circut is still enabled.
Bigsyke is offline   Reply With Quote
