sr20det ecu on sr20de
hi,
ive done some searching and i havent found a sure fire answer , but will a rwd sr20det ecu run a sr20de that has been turboed, i kno the sr20det ecu have a coprocessor that runs the direct igniition but can the det ecu run a distributor powered motor? |
i have a de ecu infact, i have a couple but i bought this jwt ecu not realizing it was tuned for a det, i basically bought a rwd sr20de and turboed using det parts, but using a distributor. how much boost can the stock de ecu run? i also have 370 injectors
Oh man, I have no clue.
You might want to sell the JWT ECU and send in one of your DE ECUs and tell JWT to hook you up with a turbo program for it. Mixing and matching without knowing the specifics of the pros and cons of that setup will only lead you into trouble. |
![]() Join Date: Sep 2003
hahaha, currently im doing the same thing right now
i have a s15 sr20de spec s motor im got a s13 redtop harness and spices out the cam angle sensor, the coilpacks runs in to the ignitor chip so that means i will be runing a s15 sr20de swap with ignitor chip. |
