Originally Posted by Matej
So like, can someone on here please make my flca about 4cm longer?
I missed this post with all the argueing we've been doing. 4cm extra length is kind of long. You can get an extra 10mm with s14 LCA's if you have an s13. To get to 4cm, you might wanna buy a battleversion LCA spherical bearing kit and weld it on to some s14 LCA's. You'll have to run s13 balljoints on them though. I don't know what the range of adjustment on Alex's LCA kit is but you'll probably have to slot the holes in the LCA's for the tension rods due to the change in angle, that is if it can lengthen the arm that much. I'm not a suspension geometry expert but if the tension rod doesn't bind with the change in angle, it should be fine.
