Old 08-03-2008, 01:04 PM   #1
sliEighty
sliEighty's Avatar
sliEighty is making a name for him/her selfsliEighty is making a name for him/her self
Send a message via AIM to sliEighty
taka line install problem.
im installing the taka lines on my t28 and i am running into trouble when i am trying to fit one of the coolant lines between the actuator arm. i was wondering if it would harm the wastegate if i turned the arm so the bend was facing up.
livin on the east cost is harder then you think...
ECM for life lll
sliEighty is offline   Reply With Quote
Old 08-03-2008, 09:55 PM   #2
sliEighty
sliEighty's Avatar
can anybody help
ECM for life lll
Old 08-03-2008, 09:59 PM   #3
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
common problem.
either take the wastegate actuator off, then install the 90 degree line into the turbo, then reinstall the actuator. i believe "burnsauto" has done this with success.
OR
use the 90 degree end on the block, and the straight fitting on the turbo.
when i did it i was like, uhh this doesn't fit, and just flipped the coolant line around and there was much rejoicing.
clark is offline   Reply With Quote
Old 08-03-2008, 10:32 PM   #4
Mister.E
Mister.E's Avatar
Trader Rating: (53)
Feedback Score: 53 reviews
yeah i used the straight fitting on the turbo and the 90 fitting on the block...it's mad simple this way.
https://instagram.com/e_lemonation/: @e_lemonation
Old 08-03-2008, 10:47 PM   #5
sliEighty
sliEighty's Avatar
alright sounds good thanks
ECM for life lll
