Old 08-04-2008, 08:26 AM   #1
98s14inaz
98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection98s14inaz is close to perfection
If you do end up getting these make sure you put the bump stops and new dust boots back on. You can trim the bump stops down a little too. That stuff is there for a reason and most likely the reason for the shocks failing so quickly.
-Retired
98s14inaz is offline   Reply With Quote
Old 08-04-2008, 08:37 AM   #2
ZX88
ZX88's Avatar
i replaced everything the fact is you are trying to put springs on an oem replacement that wasnt design for that kind of use. gr2 will eventally blow on anything with more than a 1.5 inch drop its only a matter of time and how good the road are near you.
