Old 03-28-2003, 09:08 PM   #1
Dousan_PG
Dousan_PG's Avatar
SR Clusters
question:
how much is a cluster from a SR that has a redline that starts at 7200, ends at 9K
speedo goes to 240kph
is that a standard SR gauge cluster?
how much one worth??
is there interset in them? do SR guys need the wiring harnes (subharness) as well?
Thanks for your help
im a KA boyeeee so im SR unsure on the clusters
peace.
Aaron
Pink GodziRa
Old 03-28-2003, 09:13 PM   #2
AKADriver
AKADriver's Avatar
That speedo is not stock... stock goes to 180km/h. I think the Nismo speedo goes to 240km/h, if it's not marked Nismo it might be a stock euro spec speedometer. Impul makes an aftermarket speedo but it goes to 260km/h.
That's the normal tach though.
It's a direct plug-in.
The cool 240km/h speedometer is worth a decent amount. The tach is at least worth it to someone with a SOHC that needs a new tach anyway. Dunno actual dollar amounts.
Old 03-28-2003, 09:14 PM   #3
Kid Zelda
Kid Zelda is an unknown quantity at this point
Send a message via AIM to Kid Zelda
Oh those cluster's have an aftermarket speedo.
I've seen a blitz speedo (iirc) and a nismo before.
They go for $180-240 from what I've seen
Worth it, no imho
interset, maybe for the trendy ppl who like to know they can go 240kph, if the need ever comes
Subharness ? for what ...
Kid Zelda is offline   Reply With Quote
Old 03-28-2003, 09:16 PM   #4
AKADriver
AKADriver's Avatar
He's referring to the instrument cluster subharness...
It's necessary to swap the cluster subharness if you swap from HUD to non-HUD or vice versa. But JDM and US-spec subharnesses are the same (well, functionally the same).
Old 03-28-2003, 09:42 PM   #5
Kid Zelda
Originally posted by AKADriver
It's necessary to swap the cluster subharness if you swap from HUD to non-HUD or vice versa. ).
He doesn't even mention that .. you must be a mind reader, tell me what am I thinking right now ! ? ...
*Thinking* (WoW .. this new bar soap leaves me so fresh and so clean)
Old 03-28-2003, 09:54 PM   #6
Dousan_PG
Dousan_PG's Avatar
aaah i c
hmm
i know someone who can get those all day. interesting.
ok
yeah subharness, since i dont know crap abtou SR swaps wasnt sure if that's needed
i also dont know if this is for S13, S14, or s15, ill find out
THANKS!
Aaron
Pink GodziRa
Old 03-28-2003, 09:57 PM   #7
Kid Zelda
Subharness is not needed, unless you are going from HUD to non HUD, but I wouldn't know unless you told me .. sorry, I'm not a mind reader like .. :X ..
haha j/k AKADriver
Old 03-28-2003, 11:12 PM   #8
AKADriver
AKADriver's Avatar
I'm not a mindreader... HUD/non-HUD swaps are just the only time anyone's ever brought up the subharness.
Old 03-28-2003, 11:39 PM   #9
Dousan_PG
Dousan_PG's Avatar
but im going HUD cluster!
not dash though
Aaron
Pink GodziRa
Old 03-29-2003, 07:33 AM   #10
DuffMan
DuffMan's Avatar
You want a hud but not a digital dash? I'm pretty sure that's impossible. The hud plugs into to the display unit, and I think it just gets raw numbers from it. If you want I can investigate more and post pictures.
As for the SR digital cluster, with the subharness included, these seem to be hard to find. I got one for 75 but it turned out to be a CA18DET one. The tach wont work with a KA24DE. Might work with a KA24E, in fact I'm pretty sure it will.
Old 03-29-2003, 08:10 AM   #11
Dousan_PG
Dousan_PG's Avatar
all i need is the RPM gauge and functions (gas, engine light, etc) to work. the speed i dont care about (i have a RSM)
should work. i know people who've done it. subharness should be here here shortly and the cluster i get on april 6
i dont see why it shouldnt work.
Aaron
Pink GodziRa
Old 03-29-2003, 09:31 AM   #12
DuffMan
DuffMan's Avatar
not dash though
I dont understand what you mean by this.
Annother thing. If the speedo goes that high that it is probably from europe. Unless someone from Japan swapped a euro speedo into their SR cluster, it is euro and all euro cars were CA18. Unless they swittched the tach type in 91 without changing the engine, I dont think the euro tach would work with a KA24DE.
Old 03-29-2003, 09:35 AM   #13
Dousan_PG
Dousan_PG's Avatar
sorry talking two different things. when somoene said hud i mean USDM hud clustre,, not jdm.
Aaron
Pink GodziRa
Old 03-29-2003, 09:53 AM   #14
DuffMan
DuffMan's Avatar
Ok, now I'm just more confused about what you're trying to do.
Old 03-29-2003, 10:15 AM   #15
Kid Zelda
He just wants the digital speedo, doesn't care for the HUD display on the windshield.
Old 03-29-2003, 10:18 AM   #16
DuffMan
DuffMan's Avatar
Oh, well thats no problem, thats what I have in my fastback now. You just need a tach that came from a 91-94 car (JDM or USDM).
Old 03-29-2003, 11:15 AM   #17
Dousan_PG
Dousan_PG's Avatar
this is what is going on
me have:
92 base, fastback
me get:
HUD cluster (92 cluster)
HUD subharness
so swapping htem and throwing my old cluster in my closet.
i have a89/90 HUD already but no use redoing wiring and swapping RPM gauge, so i just got a 91+ hudsetup.
im changing the bulb colors too hehehehe....
Aaron
Pink GodziRa
