turbo to manifold HELP
i am having a problem getting to the bolts on the flange from the manifold to the turbo....i can get to the first two on the outside but the other two i can not reach. the question is do i have to take the manifold off to get to the other bolts?...please help or i wont be able to go to the drift show off this weekend.
Mike AIM: projectsilvia11
89 240sx 13.22@91mph Got Spool?? AIM: S13 RKT ![]() |
Best thing to do is take the whole thing out at once. Manifold and turbo + turbo extension. than you have access to all bolts. Be sure to refill block with coolant as those hardlines are a pain to put back in the block.
now if you had a lift you could try and get at those back bolts, but I found that this is the easiest way when working with jackstands. G'luck! Jed |
![]() Join Date: Apr 2002
I second that. Just take everything out. Replace all the gaskets while you're in there. If you need new ones, get them from Wayne at Phase2 (he can probably overnight them to you). Get a new mani gasket (it WILL rip) and get a new gasket that goes between the mani and the turbo.
Then get all new stainless fasteners and lock washers so that sh*t doesn't come loose again. ![]() Eric
2002 Mazda Protege5 1989 S13 w/SR20DET (sold) |
damn that is a **** load of work just to get the mother f'er off
i think i am going to take my time and get the stuff as i can cause i don't have the time to do all this stuff. mike
![]() Join Date: Feb 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
You can get to the mani bolts without taking the turbo off? I can't get to them. I havn't tried that hard either though. This is on my SR. The motor is out of the car, so other stuff isn't in the way. just the turbo and Mani are on the exhaust side. Thanks in advance.
#6 | |
Eric
