Old 08-07-2008, 01:34 PM   #1
OBEEWON
OBEEWON's Avatar
Coolant overflow
When the engine over heats shouldnt the coolant overflow bottle fill up and spit out some coolant or boil or something?
Ive been trouble shooting a intermitting overheating issue. I have NO leaks that I can see or hear. Sometimes I get the FAINTEST smell of coolant at stop and go (so faint it could be in my mind), or if I stick my head in the engine bay right after it starts running hot then it goes away.
But the coolant level in my overflow bottle never changes. Only if I open the rad cap to bleed off some pressure do I get steam or anything out of the tank, but it never fills to the point it runs out of the tank.
Im suspecting this KOYO rad for some reason.
S13 Blacktop SR
Cooling mods.
New rad cap
Koyo
Power Enterprise Head Gasket
New Thermistor
New Thermistat
Taka oil/coolant lines to turbo
Rad Breather tank on the way
I repeat. I never see any coolant on the ground and my coolant level never changes in my rad, at least to the human eye.
Old 08-07-2008, 01:53 PM   #2
g6civcx
g6civcx's Avatar
Question: how do you know you're overheating?
Old 08-07-2008, 02:09 PM   #3
OBEEWON
OBEEWON's Avatar
Temp gauge. Engine bay is hotter than normal, air in coolant system.
Old 08-07-2008, 03:26 PM   #4
g6civcx
g6civcx's Avatar
What temp gauge are you using?
Old 08-07-2008, 03:37 PM   #5
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
theres your problem you know you have air in system already thats most likely human error..try bleeding cooling system the way ive been doing it i have the car posted parked up hill the uncap radiator as the car is running i message the upper radiator hose typically air will travel to tha highest point so since tha car it already angled tha only way out would be through that radiator neck hope this helps
S-Nation S13 is offline   Reply With Quote
Old 08-07-2008, 07:28 PM   #6
OBEEWON
OBEEWON's Avatar
Mos def not. There is air in the coolant system but not for lack of bleeding. The water in the overflow tank is cold even when the car is overheating.
Ive bled the system countless times with the front jacked up, car on a hill, waffles in my pocket, but air finds its way back in.
Old 08-07-2008, 08:38 PM   #7
g6civcx
g6civcx's Avatar
Please answer this question.
Old 08-08-2008, 06:02 AM   #8
OBEEWON
OBEEWON's Avatar
Stock in conjunction with a Autometer.
Old 08-08-2008, 06:42 AM   #9
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
Having the same damn problem man... All it takes is a pinhole leak somewhere... Heater hoses seem to be the most probable location... Fuck... who the hell wants to redo their heater hoses on an sr?
Ill work on my car, you work on yours..
Does it overheat all the time? Or just under load?
opponheimer is offline   Reply With Quote
Old 08-08-2008, 06:43 AM   #10
OBEEWON
OBEEWON's Avatar
I'm thinking the rad cap isn't opening enough to relieve pressure into the overflow tank. I never had cooling issues till I went to a KOYO.
Old 08-08-2008, 07:16 AM   #11
OBEEWON
OBEEWON's Avatar
Sucks right?
It happens with extreme stop and go in heat. Especially if I go uphill. The pressure in my system seems to have no where to go. If I crack the rad cap while its over heating, it steams and bubles out through the coolant tank then starts to cool down. Im thinking about going back to a stock rad.
Old 08-08-2008, 07:38 AM   #12
Darius
Darius is on the path to ruinDarius is on the path to ruinDarius is on the path to ruin
So you have air in your coolant system? How much?
Try starting the car cold with the radiator cap off. If you see bubbles, the HG is stuffed. Good luck.
Darius is offline   Reply With Quote
Old 08-08-2008, 01:01 PM   #13
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
try using the breather screw when you bleed your system? And lots of people have problems with the Koyo and overheating for some reason. Thermostat working properly? I would try using the stock radiator.
Nothing says racecar like a stock car with no interior.
singlecamslam is offline   Reply With Quote
Old 08-08-2008, 02:34 PM   #14
OBEEWON
OBEEWON's Avatar
Really? I think it has something to do with the neck design. Yes I have bled the system according to the FSM with the bleeder screw. However. I believe it is more effective to bleed it with the rad cap and squeezing the hoses. You get more air out that way.
What do you mean the HG is stuffed? Im not actually losing any coolant, nor are there any signs that the HG is causing this. It is a 3 layer Power Enterprise Metal Head Gasket.
I think I will try the stock Rad.
Old 08-08-2008, 03:05 PM   #15
Darius
I highly doubt your stock radiator is going to be the issue.
The coolant overflow tank is there to account for the expansion/contraction of the fluid when it heats up it expands and bleeds past the pressure regulating valve (aka the radiator cap). When the coolant cools, it contracts and "sucks" back into the cooling system to keep air from entering instead. That is why there is a minimum water level mark on the reservoir. Overheating has nothing to do with the coolant reservoir unless it is empty.
By stuffed I mean f**ked. I'm not saying the hg is damaged, but it might not be sealing the coolant passages from the cylinders and allowing exhaust gases into the cooling system. What did you do for block and head prep before installing the PE gasket?
And if you take the radiator cap off when the coolant is hot, of course it is going to bubble up and boil out because the pressure is what is keeping the coolant in liquid form. Remember the science experiment in HS where your teacher made water boil at room temp in a vacuum chamber? Same principle applies here. When the pressure is reduced, the coolant wants to boil.
Old 08-08-2008, 03:14 PM   #16
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
The issue is from air being sucked in from somewhere after the engine cools down.
Bigsyke is offline   Reply With Quote
Old 08-08-2008, 03:38 PM   #17
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
Hope you're not having problems with the head gasket, do a leakdown test to be sure. You say you're not loosing any coolant; but if there's air in the system then you are loosing coolant somewhere. You can also pressure test your radiator & cooling system to make sure it doesn't have any leaks. They make a tool that attaches like a radiator cap & lets you pressurize with a pump. I believe there is also a test you can do that shows presence of exhaust gasses in the coolant to check for HG leaks.
If the problem only happens in stop and go traffic, you might want to look into the airflow at low speeds. The koyo radiator has a thick fin density that makes it harder for air to pass through at very low speeds. What is your fan setup like?
GL
MELLO*SOS is offline   Reply With Quote
Old 08-12-2008, 01:45 PM   #18
OBEEWON
OBEEWON's Avatar
I was saying the fact that the level never changes indicates the coolant tank isnt getting to do its job. The coolant never passes the cap to go into the bottle. Meaning the pressure in the system keeps building and at no point passes the cap.
Old 08-12-2008, 02:55 PM   #19
WhiteTE72GT
WhiteTE72GT will become famous soon enoughWhiteTE72GT will become famous soon enoughWhiteTE72GT will become famous soon enough
Have you tried another radiator cap? I think pressure testing would be good as MELLO*SOS mentioned.
WhiteTE72GT is offline   Reply With Quote
Old 08-12-2008, 02:59 PM   #20
Bigsyke
Bigsyke's Avatar
This means coolant/pressure is excaping elsewhere if the cap is good. After you park the car, pop hood- wait 45 minutes, open up the radiator cap. If the fluid inside the radiator is low, then you have a leak in the system, which probably is below the IM. Or IMO the bleeder screw, which doesnt seal for S**t
Old 08-12-2008, 03:07 PM   #21
s15specR
s15specR's Avatar
Trader Rating: (18)
s15specR is making a name for him/her selfs15specR is making a name for him/her self
Feedback Score: 18 reviews
This seems to make the most sense other than the rad cap
s15specR is offline   Reply With Quote
Old 08-13-2008, 07:24 AM   #22
Brentbohn
Brentbohn's Avatar
Brentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choicesBrentbohn has made poor choices
dude change your cap. its not releasing pressure or building pressure right. make sure it seats fully inside the neck of radiator. also if its a koyo radiatior then you need koyo cap. make sure its 1.1 bar
Brentbohn is offline   Reply With Quote
Old 08-15-2008, 06:23 AM   #23
OBEEWON
OBEEWON's Avatar
I believe I found the culprit. Im seeing some fresh coolant underneath the water pump. I had to climb into the engine bay to see it. Ill be changing the water pump as well as going back to a stock radiator. I don't like this Koyo anyway.
Old 08-15-2008, 07:15 AM   #24
shmiddy
shmiddy's Avatar
when installing the new thermistate are you making sure the jiggle valve if pointing upwards?? this allows air thats in the system to leave.
you bleed the system countless times and you still get air.... from nowhere?...... maybe head gasket
i fully de-volved
Old 10-15-2008, 04:08 PM   #25
OBEEWON
OBEEWON's Avatar
For anyone who searches and finds this epic thread. I changed everything that has to do with overheating/cooling aside from the headgasket because I KNEW I did that right.
I went back to stock rad. End of story. Two events in the bag with stock rad and the car has never ran cooler.
Moral of the story:
Koyo will ruin your life and eat your children. Copper>Aluminum I dont care what you think you know, and flip what you heard.
That is all...Im going skrimshawing....
Old 10-15-2008, 07:07 PM   #26
Addicted2Kouki
Addicted2Kouki's Avatar
Addicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfectionAddicted2Kouki is close to perfection
I still think you didn't bleed right.
Originally Posted by coreansurfer View Post
zenki's are for poors and lames
with the exception of norm who is big ballin
FS:CUSCO,GREDDY,KA-Tparts
Addicted2Kouki is offline   Reply With Quote
Old 10-15-2008, 09:15 PM   #27
Bigsyke
Bigsyke's Avatar
You saw that on conan last night huh?
And yes, the filler neck on those radiators sometimes dont seal right, thus the more you drive the more air gets in.
Old 10-16-2008, 07:11 AM   #28
smelly240
smelly240's Avatar
if obee and i didnt look so much alike i would agree with him... but since we're virtually twins - he has to die (plus his radiator issues made him eat a baby)
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
Old 10-16-2008, 08:43 AM   #29
OBEEWON
OBEEWON's Avatar
Yes you know what??? Now that I think about it you are right...
wait no...no...thats silly.
Old 10-16-2008, 08:46 AM   #30
OBEEWON
OBEEWON's Avatar
That baby gave me food poisoning/bubble guts.
Stop stealing my womens with you good looks and cunning wit. Just cuz u muh evul twin gives you no right.
Everyone was wrong. Deal with it. Nissan techs knew what they were doing. Koyo can lick my toe jam, maybe ill try thier copper rad.
