Old 04-01-2003, 01:23 AM   #4
AceInHole
Autox Technician
AceInHole's Avatar
AceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfectionAceInHole is close to perfection
the RRFPR and fuel pump (as much as I would not go that route) should be fine for low boost. Although, getting a JWT ECU and 370cc injectors would be a "better" way to go. Really, you could get away with using the stock fuel pump with the JWT. So... what RRFPR are you getting anyways? The Vortech SFMU is well over $200 IIRC.
As for the IC, you probably know JGS makes IC's that I think have Spearco cores (they use the Spearco equivolent flow charts on their page.....). You can get a "Starion style" IC for like $400, with pretty similar dimensions to the HKS you were looking at.
AceInHole is offline   Reply With Quote
