Old 08-16-2008, 01:09 AM   #1
WangonwWarrior
Location: Amerika24 alabama: Where if your not first..... your last
WangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant futureWangonwWarrior has a brilliant future
engine break in?
Im almost done with my KA24det ive been building. I put new rod bearings and main bearings on the engine along with all the other gaskets etc... The cylinder walls and piston rings were fine so i left those in and did not replace them. I have installed my turbo kit and safcII and i do not want to drive the car until its tuned on the dyno. My question is do i need to break this engine in before it goes on the dyno? Or do you only need to break it in when new rings and pistons are installed? This might be a stupid question but i cant find anything on it... I just want to know if it is safe
WangonwWarrior is offline   Reply With Quote
Old 08-16-2008, 01:45 AM   #2
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
i think they could break it in on the dyno
s13boy89 is offline   Reply With Quote
Old 08-16-2008, 01:50 AM   #3
boosted98gst
boosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant futureboosted98gst has a brilliant future
Send a message via AIM to boosted98gst
Every engine build ive done Ive ran cheap oil through the first 1k mile changing it out the first 100 checking the filter by cutting it open, then 300, 500, 800 then 1000, then switched over to full synthetic, ive had everything from 540 awhp evo to a 601awhp dsm and now a rb25det coupe, synthetic is too thin for engine break in period imop , you need somthing cheap that sticks to parts better then synthetic
boosted98gst is offline   Reply With Quote
Old 08-16-2008, 01:51 AM   #4
gijoe69
gijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant futuregijoe69 has a brilliant future
Send a message via AIM to gijoe69
umm.......how are you gonna get the car to the dyno? drive? trailer? I say screw the dyno just drive it until, you think its broken in then dyno it .....
gijoe69 is offline   Reply With Quote
Old 08-16-2008, 01:52 AM   #5
TravisSW
TravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfectionTravisSW is close to perfection
Send a message via AIM to TravisSW
Personally, this is my plan for my KA-T:
Build up the motor internally, once that is done. Run it N/A for a while to get things breakin in and ready to go. After a couple of months and funds renew AND when I feel comfortable with it, I'll plop on the turbo accessories.
1986 Porsche 944 Turbo (951)
1995 Nissan 240sx (S14) Miss ya.
TravisSW is offline   Reply With Quote
Old 08-16-2008, 02:01 AM   #6
Massimo Power
Massimo Power's Avatar
Massimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to allMassimo Power is a name known to all
Send a message via AIM to Massimo Power
Just drive it to get it tuned and tune it and break it in on the dyno. If you had piston rings installed thats when the big break in takes affect. I would suggest as stated above to run regular oil in it for the first 1k miles n do a few oil changes in between to get rid of the break in metal. Other than that you should be fine. When i fully built my motor it went staight on the dyno with a hard break in and straight to a time attack only 200 miles later.... been running perfect ever since with very exceptional compression.
but good luck... !
www.massimopower.com
PH: 1(951)402-5386
EM:[email protected]
Special Thanks To:
www.aeperformance.com
www.domospeed.com/blog
For Their Continued Support
Massimo Power is offline   Reply With Quote
Old 08-16-2008, 09:59 AM   #7
WangonwWarrior
Yes you guys are correct about breaking it in with cheap motor oil then switching to synthetic (that is what i did on my last NA KA build everyone reccomends doing that) I can just throw the car on the trailer and haul it to the dyno. I have even considered TravisSW's plan and add turbo parts after the break in, the thing about this is look at cars that come from the factory with turbo chargers- they are broken in with all the turbo parts in tact BUT they are already set up: air/fuel/boost from the factory.
Old 08-16-2008, 10:01 AM   #8
WangonwWarrior
I just dont want to drive my car around town during the break in period with it running way to rich... i cant afford to build another engine right now
Old 08-16-2008, 10:20 AM   #9
nismo tuned s14
nismo tuned s14's Avatar
nismo tuned s14 is making a name for him/her selfnismo tuned s14 is making a name for him/her selfnismo tuned s14 is making a name for him/her self
When I was breaking mine in, i changed the cheap oil and filter after babying it for 1k miles. Then I stayed under 7-8 psi for the next 1-2k miles. It's still running extremely well 17k miles later.
nismo tuned s14 is offline   Reply With Quote
Old 08-16-2008, 11:04 AM   #10
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
417racing.com • View topic - How to break in a New engine
there ya go.
SexPanda is offline   Reply With Quote
Old 08-16-2008, 11:20 AM   #11
pinkarrowsnow
pinkarrowsnow's Avatar
pinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura aboutpinkarrowsnow has a spectacular aura about
Break it in the mototune way Break In Secrets--How To Break In New Motorcycle and Car Engines For More Power thats how I plan on doing mine when I finish my build in a week or so.
pinkarrowsnow is offline   Reply With Quote
Old 08-16-2008, 11:25 AM   #12
hunter8411
hunter8411's Avatar
hunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond reputehunter8411 has a reputation beyond repute
Send a message via AIM to hunter8411
I may be wrong here, but I thought the purpose of the break-in period on the car was to allow the piston rings to set properly with the Cylinder walls. Now since you did not replace them at all, then they should not need to be broken in right?
(Someone please let me know if I'm wrong)
Although personally I would still take it easy for the first 500-1000 miles or so to make sure it is all working fine.
When I broke in my newly built motor I did it the mototune way and it seems to have worked fine.
hunter8411 is offline   Reply With Quote
Old 08-16-2008, 12:46 PM   #13
RedtopTech
RedtopTech's Avatar
RedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud ofRedtopTech has much to be proud of
Well piston ring gaps are indexed when installed to reduce the amount of blowby. They are worn into the cylinder walls in there installed location. Once they are removed and reinstalled, they wear into the new location because the crosshatch on the walls wont be prominant enough without being honed.
RedtopTech is offline   Reply With Quote
Old 08-16-2008, 01:09 PM   #14
WangonwWarrior
exactly my question^ i think the bearings just need a few miles (like 100miles maybe) and they will be fine.
correct me if this is bad: I am going to put the stock injectors on my KA instead of the sr 370cc and run them for a few hundred miles and stay out of boost. That way it will not run rich it will run lean if i get into boost but ill stay out while the small injectors are in. Sounds like a good plan to me, what you guys think?
Old 08-16-2008, 01:52 PM   #15
pwr-adr
pwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the roughpwr-adr is a jewel in the rough
its what I did with my ka-t.
pwr-adr is offline   Reply With Quote
Old 08-16-2008, 03:51 PM   #16
ericcastro
ericcastro's Avatar
Sounds like it might work better.
And if you are thinking of Dyno, before the break in, go on youtube and look up dyno engine explosions and such
Old 08-16-2008, 03:52 PM   #17
SexPanda
SexPanda's Avatar
Well, one thing you DONT want to do is run your engine lean...
If you dont know what happens when your engine is run too lean. Its not pretty. Find some medium sized injectors between stock KA and stock SR if you can.
Old 08-16-2008, 04:31 PM   #18
surge s14
surge s14's Avatar
surge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymoresurge s14 is not welcome here anymore
i havent decided how to breakin my engine yet
new pistons, rods, bearings, valves, springs, 740cc, gt2871r
and no tune...yet
what the best route i want a reflashed ecu thou
surge s14 is offline   Reply With Quote
Old 08-16-2008, 07:00 PM   #19
WangonwWarrior
well if i run the stock injectors and stay out of boost then it should not run rich, but you never know. i have a big ass exhaust and its still going to be pulling some air in even out of boost thats why im afraid it might run lean. Ill run it for a little while with the stock injectors and check my plugs to see what is going on
Old 08-16-2008, 09:46 PM   #20
S14DB
AFC #1
S14DB's Avatar
If the rings were reused and the bores not honed then all you need to do is get the oil primed before starting. Still need to change the oil and filter after 500miles as the bearings break in and wear off imperfections.
As far as oil. Organic and Synthetic of the same weight, WEIGH THE SAME AND ARE THE SAME THICKNESS(viscosity). Stop this ignorant bullshit that a synthetic is thinner then a organic. The label on the bottle is the weight/viscosity. 10w-40's are all the same weight. If you want to talk about friction, hell, lets talk about backpressure then too...
